Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Cant seperate pump motor from jets tring to clean jets
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
Every thing is made to come apart, look for any screws , if no screws then it doesnt come apart.
Posted on Mar 28, 2010
Why has pump stopped working?
could be a start/run capacitor for the motor or a leaking pump[ seal has rusted the bearing of the motor causing it to jam
Nov 12, 2015 | Pool & Spa
Hot tub comes on jets want start
most hot tubs have two motors. one is a circulation pump to move water when the heater starts and the other comes on when the jets are being used. from the sounds of it, the one pump isnt running properly
Oct 20, 2015 | Pool & Spa
Pump runs I don't draw water
is this a submursible pump that is deep under ground, or is it a jet pump in your basement. could have a bad impeller, lost prime, bad check valve. if its deep under ground and your sure its running if you have a spec sheet on the motor you can check amp draw to see if your getting the FLA range need a amp meter to do this. to see if its pumping sometimes there is a spline seperating the pump from the motor and they can go bad and the motor can still run.
Aug 24, 2013 | Cars & Trucks
I have motor and blower on workbench. I am tring to replace the motor of my kenmore dryer. I have the new motor can't seperate motor from the blower to replace. Manual says panhead screw.There is no...
There are 2 different blower wheels: 694089
and PN 697772
Dryer Motor replacement is here:
Between the 3 videos you should be able to acomplish the task.
Thanks for choosing FixYa,
Kelly
Sep 17, 2011 | Kenmore Dryers
Trying to replace motor cant figure out how to remove impeller,
Might be a screw in middle of impeller with reverse thread. If so, remove. Remove back cover of motor, hold center shaft with wrench and unscrew impeller from shaft.
May 05, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
Windscren washer not working on my peugot207cc
Check the fuse for windscreen washer.
If you can hear the washer motor running but no water comes out then check the washer motor under the side wing cover.
Pull the rubber pipe from motor and then let the washer run to check wheather water will be pumped or not.
If yes the problem is on the side of rubber-pipe to spray-jets on bonet (may be spray jets need some cleaning).
If not then then the problem is in washer pump. The dirt that reside during the time inside washer pump (the plastic pump attached to the washer motor) causing the problem.
Pull out the whole pump motor from tank and disassemble the pump to clean the free moveable conical metal rod and rubber washers (takes about 1.5 hours for cleaning). If you don't want to do it then convenient is to buy another washer (set of motor+pump).
Jan 16, 2010 | 2006 Peugeot 405
I have a91 xr250l w/ a pumper carb. Will not start.
It's a '91 model. When is the last time you had the carb cleaned out? Sounds like you've got a stopped up low speed jet. The hole in that jet is less than 0.020" in diameter. Doesn't take much to obstruct that. Do you run a fuel filter in your fuel line? I'd pull the carb and take the float bowl off. You'll see a large jet directly in the middle of the carb. Just off to the side, you should see another small jet. This is the low speed jet. Take it out and clean the jet using aerosol carb cleaner. Do not stick any wire or anything through the jet. You should be able to hold it up the the light see through it. Set you idle mixture screw at one turn off the bottom to begin with. Once you get the engine running and warmed up, adjust for highest smoothest idle speed. Good Luck
Nov 25, 2009 | 1991 Honda XR 250 R
Snowmobile carb. problem
I would say no. Carburetors can be tricky. They might need a good cleaning. Jets might be dirty. Check the fuel filter aswell.
May 26, 2009 | 1998 Volkswagen Beetle
Need to replace pump motor i have a new motor but i cant seperate the pump on the motor armitur
i was having the same problem with my pool
motor, and couldn't saparate so i replace it
as unit both pump and motor,
May 08, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Wiper Fluid Not Spraying
First of all-Check ALL of your Fuses. Inside the Reservoir there is a Small Pump. This is the Pump that you need to replace if no Fuses are Blown.
Jan 12, 2009 | 1999 Chevrolet Suburban
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
107 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
