Dayton E52 Utility Heater Logo
Posted on Feb 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
Dayton htr (kerosene) runs fine at first. After 10 min, it shuts off. Pushing the re-set button re-starts it for another few minutes. Have tried installing a new board, cleaning photo cell, etc. and it still does it. Just want it to run continuously.
David Spradling
Level 3:
Top Expert:
  • Dayton Master 13,520 Answers
  • Posted on Aug 21, 2022
David Spradling
Dayton Master
Level 3:
Top Expert:
Answers
13520
Questions
0
Helped
928058
Points
28384
If burners are clogged it will run hot and overheat
wadingriver
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 2,248 Answers
  • Posted on Jan 17, 2022
wadingriver
Master
Level 3:
Renaissance:
Answers
2248
Questions
7
Helped
381955
Points
5417
Make sure fuel tank is vented. Try keeping fuel cap loose and see if it stays running
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
431
Points
The heater runs good but don,t seem to run clean.
will start to make eyes water
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Feb 21, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
8612
Points
19
Check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
How to ajust dayton 155000 btu torpedo heater when running smell like kerosen
You say: When running it smells like Kerosene--
That is what you are burning in it, right?
Is it smoking--- like there is a poor combustion mixture?
-- like maybe not enough air pressure?
There is a pressure adjustment for both-- Please check the manual for adjusting the pressures for your particular model.
Unit run for several mins then shuts off
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
1helpful
2answers
Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Top Dayton Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
