Question about Philips VR750 VHS VCR
Why is my vcr chewing up tapes - Philips VR750 VHS VCR
  • Philips Master
  • 5,390 Answers
The answer is easy take the top off the unit, and with an old video tape try it and watch what the video does. This is the only way really as the causes of tape damage are many, including objects that have got into the works. The only tape chew fault that can be put down to a single thing, is the crinkle bottom or top edge. Which is caused by the pinch roller being worn.
Once you see what it does you can post again and describe it, we are FixYa should be able to pin it down.
Posted on Feb 03, 2010
3 Suggested Answers
  • 883 Answers
SOURCE: vhs tape gets chewed
Dear William,
the rubber belts and rubber capstan need cleaning/conditioning. you can attempt this with alcohol swabs and if you find rubber conditioner (in the past was easy to find in audio supply stores) apply some of this also. if this treatment does not solve, then may need new rubber belt kit. good luck.
Posted on Dec 27, 2007
  • 44 Answers
SOURCE: My vcr chewed up a tape and now it is not working
If you are a handy person you could first unplug the VCR from the power outlet and remove the cover to see if some of the tape that was chewed up is wrapped around some of the tape path mechanism.
If you know someone techie who has some experience let them look at it and throw them a $20 for cleaning it.
May be best to just purchase a new DVD/VCR .
Blessings,
A/V Media Tech Guy
Posted on Nov 25, 2009
Why is My vcr chewing my tape? & how do I fix this problem?
u have a bad take up belt try this put the tape in hit stop push ff let run a little stop hitrwind let run stop then hit play might take 2 times it will fix
Sep 22, 2014 | Televison & Video
Awia HV-FX7500K has started to chew the vhs tape & Now everytime you place the VHS in the VCR it reads and ejects it within 5 seconds.
The biggest cause of that is a worn pinch roller. Replacement is the only cure. You could take off the top cover and watch an old tape being inserted. You will soon see where the tape goes wrong.
Sep 18, 2014 | Televison & Video
How do I stop the vcr chewing tapes?
Probably bad drive belt need replacing.
My vcr chewed up a tape and now it is not working right. When you put a tape in the vcr, "PLAY" will come on the screen as if it is going work. Then it goes to a blue screen and turns off.
Blessings,
A/V Media Tech Guy
Nov 23, 2009 | Televison & Video
Tape chewing
use a vcr cleaning tape.
Feb 18, 2009 | LG XBR446 DVD Recorder/VCR
Tvcombi
You need to send it to a repair center because the problem might be a bad idle on the vcr deck player ,and you can not be able to fix it.Good luck.
Jul 25, 2008 | Televison & Video
Vhs tape gets chewed
Dear William,
Dec 27, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
This model is the W528 VCR, but my manual includes both models
Does it do this with other television sets? If so, then it indicates the problem resides in the VCR. Rolling as you describe suggests either the VCR isn't producing a clean enough vertical sync pulse in the video signal, or the TV circuitry isn't processing the pulse properly. First, try cleaning the heads (not just the video head, but also the audio/control head which is to the right of the rotating video head. If this doesn't fix the problem, an electronic problem is likely. Unless this is a high dollar unit, repair is not recommended, as VCRs of the last 10 years or so are essentially disposable. I've done some looking on the 'net regarding copy protection, and it doesn't look like this is an issue here.
May 02, 2007 | Toshiba W522 VHS VCR
VCR Chews up tapes
it happened to me too. the only way to fix it or take the vhs from the vcr is to open it.
Jan 17, 2007 | Panasonic PV-C1320 13 in. TV/VCR Combo
Philips VR750 VHS VCR Logo
1,313 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
