Question about ADIC Scalar i500 Tape Drive
Cannot calibrate drive
Two errors
T019 cannot calibrate drive, motion OK
T020 cannot calibrate storage, motion OK
2 Suggested Answers
  • 181 Answers
SOURCE: Problem with ADIC500 tape library
Update firmware of tape liberary and drive
Posted on Apr 10, 2012
Robotic hardware error and I/O station status shows open
A physical obstruction in the path of the robot's motion. Examples
include tape cartridges that are extending from the picker assembly or
from a storage location, as well as tape cartridges or debris that may
have collected on the floor of the library.
2. A large number of electrical hardware failures. Firmware or hardware
detects that motion control is not occurring properly (encoder issues,
motor driving circuits, motor winding issues, etc.)
3. A relatively small number of mechanical hardware failures that do not
result in the detection of a complete obstruction, but where motion
control generates robotics firmware error codes (contamination or damage
to encoder wheel, high friction, etc.).
Possible FRUs is Robot Assembly
Sep 01, 2013 | IBM System Storage TS3200 Tape Library...
Nov 30, 2011 | ADIC Scalar i500 Tape Drive
Slimtype dvd a ds8a1h ata device is not working. Previously worked fine. Now i get a 'Power calibration error'.
"Power Callibration Error" is the result of low laser power.
Open the DVD drive and carefully, with a cotton bud, rub the laser lens gently in a circular motion.
Try again.
If still faulty, replace the drive.
Dec 15, 2010 | HP Pavilion dv6000z Notebook
Drive not recognising MO disk. Orange light flashing endless.
Your drive is not spinning up because of ither a read channel calibration error- or a focus servo error- assumimng your using the same media you always have been- and its not REALLY dusty.
Read Cal failure is caused by the controller and the Focus Servo Failure is caused by the optcs module-
repair cost $285 for either.
At Optical Storage Repair
osrsinc@charter.net cheapest , fastest and best.
Aug 13, 2010 | HP SureStore Optical 9100mx (C1114M)...
Open tray error and thensome.
Unreadable disc errors or open tray errors are commonly fixed by pot calibration or laser assembly replacement. Pot calibration is the cheaper of the two, and if it fails and burns out the laser, well, replacing the laser would be the next step anyway.
You shouldn't calibrate the pot without an ohms reader simply because you can burn out the laser, but you CAN wing it. I'd advise doing some searching on DVD Drive pot calibration for the Xbox 360, simply because I don't know which drive you have so I can't help identify anything for you.
I will say you have to disassemble it down until you see the motherboard, take out the DVD drive, open it up, and then calibrate the pot with a very small screwdriver. The location of the pot depends on your drive. If this fails, then buy a new laser assembly and replace it in the drive.
p.s. pot calibration is fancy terminology. There are basically 2 "screws" inside the drive, 1 pot is the DVD/games, and the other is CD. You'll want to very slightly tweak the DVD/games pot until it works, testing with each tweak. You barely need to adjust this "screw" for a significant change to happen. Also, always test with a DVD and then a game. It will read a DVD before a game.
Apr 09, 2010 | Microsoft Xbox 360 Console
I HAVE AN ERROR CODE
To solve use this steps carefully.. Follow these steps.....
  • On the printer's front panel, press the ENTER key.
  • Using the Arrow keys, scroll to Utilities , and press ENTER.
  • Press the ENTER key and the Up Arrow key simultaneously (allows access to the Service Test submenu).
  • Using the Arrow keys, scroll to Bail Calib , and press ENTER.
  • The bail will rise.
  • Press the Up Arrow key until the bail makes a slight falling motion (approximately 1/4 inch). Each time the key is pressed, the bail will rise slightly.
  • When the bail makes the falling motion, press ENTER to write the calibration value to the EEROM. This is the correct up position for the bail.
  • When the message SUCCESS CALIBRATION press ENTER appears, press ENTER.
  • Press the PREVIOUS key until the main front panel screen appears.
  • Turn the printer off, then on to store the calibration value in the EEROM.
  • Turn the printer on and load media
Thanks
Aug 14, 2009 | HP DesignJet 450c InkJet Printer
change the cables of dvd drive, also check power
Sep 28, 2008 | Imation 16575 2.4x DVD+RW Storage Media
Error on tally genicom 6312
found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Jul 01, 2008 | TallyGenicom 6312 Matrix Printer
Tally T6100
You lost the sensor calibrations. Grab the service manual. Do the four fault clear, enable tech access mode and calibrate paper motion, paper out and platen.
May 23, 2008 | Tally Line Matrix T6050 Printer
Power calibration eror
Just install Nero 6 and that will fix it!!!
Nero 7 and 8 have communication problem with DVD RW drive!!
good luck
Jan 22, 2008 | Imation 16575 2.4x DVD+RW Storage Media
ADIC Scalar i500 Tape Drive Logo
343 people viewed this question
Top ADIC Computers & Internet Experts
David Payne
David Payne
Are you an ADIC Computer and Internet Expert? Answer questions, earn points and help others
