NonStop Graphic Problems on 5870
First of all here seems too many problem but i think all of them is connected to one reason.
problem 1: (dirt 2)
There is many stuttering in the game. when i play it starts to stutter and immediately it gets very fast grapchis. afterthat again it starts to stutter and grapichs gets very fast. i tried to get a fps but i could not. I can not get a benchmark report on Dirt 2. I complete benchmark test in the game but ne result is shown.
problem 2:
the stuttering and getting fast is shown with almost all games. and in crysis(for example), there is no v sync enabling option in graphic options. so some tearings is shown during game.
problem 3:
low fps and performance. the computer systems that are very similar to my sistem gets better points from tests like 3dmark06 although i overclocked my sistem.
* all drivers of my hardwares is all updated. catalyst 10.1
* I do not even think that system is getting hot too much. all tempatures is all okay. fans works with their full speed.
my sistem:
ASUS P6T SE X58 Socket
Intel Core i7 920 @3.5GHz
OCZ 4GB (2*2) Kit Platinum Edition DDR3 1333MHz@1400MHz CL7
Sapphire HD5870 GDDR5 1GB 256Bit 900MHz@1300MHz
thermaltake 750w
coolermaster haf 922 midt
the fan speed of the vga is %100. first i suspect of getting very hot and i got fan speed %100 but no change
Thanks much !
  • 111 Answers
Update your drivers to 10.2, see if that fixes the problem. http://game.amd.com/us-en/drivers_catalyst.aspx If it doesn't get back to me
Posted on Mar 07, 2010
Pc monitor is all green what is wrong
There can be a no. of reasons behind this.
1) Simplest one: your monitor picture tube has gone crazy. You gtta invest on a new one. Consult a good technician.
2) The chord connecting your monitor to the CPU is problematic. Try blowing it to remove dirt and fixing it again firmly.
3) In the extreme case the graphic card on your motherboard is defective. But there very less chances of it. In this case you need to buy a new motherboard.
Jul 04, 2013 | Computers & Internet
AGPTEK sc9-5870 thermal printer won't print
I got mine to work by changing the port from USB001 to USB002 prints great now, there is problems with installing on windows 8, you have to disable driver verification or the driver won't install.
Good printer don't give up on it.
Feb 07, 2013 | Brainydeal Agptek High-speed 58mm Pos...
OC problem - boots into black screen after botched OC
Hello booting to safe mode is by pressing the F8 button
while you boot
And select one of the boot options useualy boot with network support. Out of safe mode is just to reboot.
Try to set the graphic settings back to factory specs.
If you still have black screen you might have burned the gpu chip
and the graphic card must be renewed.
If you have any luck try to renew the driver from here:
http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_vista64.aspx
This is the windows 7 driver 64 bit.
If you are running another windows system select it here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Hope this will help you
Nov 13, 2012 | ASUS ATI RADEON HD 5870, (1 GB) PCI...
The motor is making noise but otherwise working fine. What should I do.... if I upgrade, what should I get?
hey there,depends on what your budget is,
heres your 2 best choices:
Nvidia gtx 460 geforce:http://www.amazon.co.uk/Palit-SONIC-nVIDIA-Geforce-Graphics/dp/B003VJW0WS/ref=sr_1_fkmr0_1?ie=UTF8&qid=1296928678&sr=8-1-fkmr0
Radeon XFX HD 5870:http://www.amazon.co.uk/XFX-Radeon-HD-5870-DisplayPort/dp/B003CXKM4G/ref=sr_1_23?s=computers&ie=UTF8&qid=1296928833&sr=1-23
good luck
Feb 04, 2011 | Jaton VIDEO-198PCI-64TWIN (64 MB) Graphic...
Is there anyone who knows if graphic card Readeon HD 6870 works with the motherboard Gigabyte GA-P35-DS3. I have already mounted the card but encountered problems getting signal to the monitor. Would be...
There is no reason why this graphics card should not be working. The Gigabyte GA-P35-DS3 has a PCI-Express 16x slot. The HD6870 requires at least 194W at idle and 320W under load (when playing games or video encoding). This leads me to believe that maybe the card isn't getting enough power.
The HD6870 needs 2X 6pin power plugs as show below directly from your power supply.
Motherboard power is not enough so make sure you have connected these plugs firmly and that your power supply has the relevant plugs.
If your power supply doesn't have two 6 pin power plugs then you can use the molex to 6pin coverters that came in the HD6870 package shown below.
Jan 09, 2011 | Sapphire RADEON HD6870, (1 GB) DDR5...
Ringer sound isnt working and its at calls level 5. but vibration works fine.
2 reasons of this problems
1 reason
setting >> profile >> edit used profile >> call alert type >> different type mode there, (select ur useful type) i think u select melody type call alert
2 reason
ur mobile speaker is problems
1.loose connection
2.speaker out, --- change the speaker
Sep 09, 2010 | Samsung Rugby SGH-a837 Cell Phone
Interested to purchase used delta surface planer 24 RC-63D serial #1605 like to know value & if they have any problems
Rule of thumb is 1/3-1/2 of retail if its in good shape.
Look for excess slack in the hieght gears not a biggie but annoyng. Main thing I have seen is the blades. Seems some people think its fine to run dirty hunks of wood through to clean them up. Think concrete/nails sand etc. Checks the blades they are not that cheap to replace if they have nicks. That seems to be the main reason for selling these.
Aug 04, 2010 | Delta Machinery Delta 22-610 RC-63D...
I installed my brand new ati radeon 5870 into my dell precision t3500 and when i start up the computer a long beep sound with a loud fan and the monitor shows nothing
You've left something unplugged!Check the motherboard connections and the power connections for the card.Speaking of power,check the system requirements for that card.Do you have enough Watts to run it?Let me know how it goes ,if it won't work with the card installed.Put the computer back the way it was and see if it runs.It will help you to remember what you unplugged to install the new card.
Feb 20, 2010 | ATI RADEON Graphic Card
8600 gt nvidia card
Hi ,
Did you try re-installing the drivers of the card , If the performance is slow it can be due to other reasons , your processor taking more load , go to Task Manager and check the Ram and Processor utilization.
Please do let me know the system configuration.
Jan 02, 2009 | XFX NVIDIA GFORCE2 MX 200 (64 MB) Graphic...
Graphic render fail
This could be because of 2 reasons.
1. that the drivers installed are the incorrect drivers for that particular camera
2. You can disable Windows Live Messenger it seems to be interefering or conflicting with the web cam somehow.
Happy Holidays
Dec 24, 2008 | Computers & Internet
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
