Question about Grilling
New gas grill fell in storm
Hi
I purchased a new commercial series Char-broil grill (4 burner model) last summer.Well much to my shock and dismay,during a very windy rain storm last week I heard a loud crash in my back yard.Somehow the wind must have got under it hard enough to topple it over!! This thing is very heavy,I couldn't believe my eyes.Needless to say, I'm very bummed out about it.
Anyway,visually everything looks ok,no outward sign of damaged or broken parts and nothing was knocked out of alignment.However,it now won't light properly.I press the ignitor and it sparks up ok,then a flame shoots out around the knob area.One of the burners lights but kind of weak then goes out.I smell heavy propane so I turn it off...don't really want to mess around with it.
Any help would be greatly appreciated..thanks in advance.
  • Gary Davd
    Gary Davd May 11, 2010
    realign your burrners in the orfice slots
  • 833 Answers
Sounds like either a defective valve or that the components to it have misaligned. Inspect all valves and other parts. If some look different from the majority, replace them. Do not use the unit until you do.
Posted on Mar 16, 2008
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
Char-broil spares new burner.
Hi Gary...
I am sorry but you will need to put in the model number of your grill before I can help you.
I went to the Char-broil webpage and talked to one of the reps there thru a chat window and he said you need to have the model number to be sure to get the right part, otherwise you would have to risk using a Universal Burner Unit that may require modification to function in your grill.
I will give you the Char-Broil webpage on this webpage you will see an "exploded view" of your grill and off to the right you will see a window that you can enter either a part number and or model number to locate your parts.
Please take time to rate me
http://www.charbroil.com/Store/ReplacementParts.aspx
Aug 04, 2011 | Char-Broil 7000 Quick Set Gas Grill
The burners will not light. It appears that they are no getting any propane from the tank. Unfortunately, I have missed the manuel and this is a brand new grill. First time trying to use it and have...
The problem is more than likely the OPD Valve in the gas tank. To solve this problem, turn the Tank Valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY,VERY SLOWLY (Slow motion, slow). Once it's fully open, light the burner farthest from the tank first and turn it to it's highest setting. Does the flame height look correct? If so, light the remaining burners following the same procedure. Now, to all the flame heights look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly. If it didn't solve the problem, make sure you have adequate gas in "old propane tank from the other grill."
To further help you, I have included a link to your Owner's Manual that you can download and print for future reference. http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463247310%20english.pdf
In addition, here is a link to Troubleshooting Gas grills
http://www.charbroil.com/Support/Troubleshooting_Level2/4/Gas-Grills.aspx?Model=463247310
I really hope all of this information has helped you solve the problem. Please let me know and Happy Grilling.
May 22, 2011 | Char-Broil Grilling
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Regulator Repeatedly Reduces The Gas Flow
The new regulators will automatically shut down or reduce flow if the it senses that the flow is too high (as in a line leak or break). It can also be folled if you open the valve too quickly. There is a special plastic plug that can reset a tripped valve in the new tanks. (Mosquito Magnet supplies one with their product).
The other thing is that there is a recall going on at Char Broil of defective thermometers that are reading too low.
Sep 28, 2009 | Char-Broil Commercial Stainless Steel...
SEVERAL DAYS AGO,THE GRILL GREASE CAUGHT FIRE,TEMP WAS 600,TURNED OFF IMM.SINCE THEN GRILL LIGHTS,FLAME IS VERY LOW OTHER BURNERS LIGHT BUT FLAMEIS LOW. HAVE CHECKED GAS SUPPLY.EVEN PUT ON A NEW TANK.SAME...
The regulator is damaged. This is the little round between the hose connected to your knob adjustment and the Gas tank. This one is not expensive. it costs less than 30 bucks. Good Luck.
Jul 06, 2009 | Grilling
New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Jun 23, 2009 | Grilling
Char Broil Commercial Series
What you are expierencing is a restriction in either the line coming from the regulator or a bad regulator. Most likely I would lean towards the regulator.
Jun 11, 2008 | Grilling
Char Broil commercial grill won't heat pass 300 degrees
I had a similar problem and thought the propane kept running out....come to find out it was a defective regulator. $21 at the local ACE store as running to LOWES and trying to get a point across to a 17 yr old summer help college kid for a intermittent problem seemed more challenging then it was worth. Would barely light the burners and would not get over 200 degrees. Ripped it apart...blew through all the orfices including the regulator put it all back together and would work for a while then fail again. Good luck!
May 30, 2008 | Char-Broil Commercial Stainless Steel...
Grilling Logo
313 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
