Question about KitchenAid KAWS850L Top Load Washer
How do i remove agitator from a moffat mnxr1070, there does not appear to be a bolt under softener cap just plastic?cause there is oil or grease coming out.blending with clothes. what is the problem?
  • 234 Answers
SOURCE: How do I take out the agitator?
I'm not sure if this is the same as your machine but here is a link to a possible solution:
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
I hope that this solves your problem.
Posted on Apr 15, 2009
Jimster
  • 240 Answers
SOURCE: Agitator loose
Just reach down between the basket and the agitator, and lift really hard straight up. Be sure not to hit yourself in the head when it pops loose. GE agitators just snap on to the air-bell underneith. Be sure that bell isnt loose after you remove. Good Luck!!!!
Posted on Feb 03, 2008
  • 219 Answers
SOURCE: I need to remove agitator from my maytag washer,
take the softner cap off then should be able to get to it with an exteison and a half inch socket
Posted on Mar 17, 2009
  • 77 Answers
SOURCE: cant remove agitator. Fabric softener cap is off but i do not see a screw or bolt to remove the assembly. agitator is only weakly working
There should be a 7/16 bolt in the bottom of the cup once you have taken the cup out. Its kinda deep you would need a longer extension. Also this agitator bolt usually has a gasket material attached to it and it may be covered by another cap.
Posted on Apr 17, 2009
  • 583 Answers
SOURCE: My washer has had streaks of grease coming from
GE style washer Common problems: - greeseOil on the clothes or floor. In most cases a new transmission will be required. You can rebuild the Trans for oil on the floor, but I find it best just to replace the transmission with a rebuilt one = less problems and faster repair. I have a parts breakdown of the old style transmission here. How to access the washer information.
Change transmission in GE washer-Take transmission out for repairs. - Unplug washer. Remove agitator from washer by pulling straight up on it, some agitators have a bolt under the cap, remove cap and look for a bolt first. Remove the agitator bearing from transmission hub. Get top up by pressing on 2 clips located about 6 in in from side between top and cabinet. Putty knife or flat blade screwdriver works well here. Take the filter flow tube off. Lift top. Remove three bolts holding basket to hub, and use a 12 POINT 1/2" socket to remove the bolts. Lift basket out of washer. Remove the two clamps holding the black boot to the tub and to the transmission. There are six bolts holding the transmission in the washer. Remove the bolts and lift transmission out of the machine.
To replace bottom seal - Turn trans. upside down in a bucket, put in vice, etc. Remove the nut holding the drive pulley on. Take drive pulley off. You can now pry the oil seal out of the trans. bottom and replace. If you wish to put the proper amount of oil in the trans. you will need to remove the bottom cover. Unless you have lost a great deal of oil, I would bypass this. I would estimate the oil loss and put in a lesser amount through the opening where you will be putting the new seal. When replacing the pulley, do not turn the nut holding pulley on. Hold nut stationary and turn pulley in the direction that nut will tighten. This will keep you from separating the hub, torque spring, and drive collar in the transmission. If you see evidence of water in the transmission, my recommendation would be to purchase a rebuilt transmission and repair in that manner. You may wish to do this regardless of the condition of the trans. You will receive a one year warranty with the rebuilt trans. I have a parts breakdown here for the transmission if you need it.
Usually you have to only add a little oil to replace what was lost...not much...really!!
The oil used is a Non-detergent, Gear oil approximately 90 weight. The main pulley seal is WH8X281 and foam nut seal is part # WH2X671.
Posted on Jul 13, 2009
Can't remove agitator on hotpoint washer
I have this same model of Hotpoint washer. I pulled up on the agitator and that separated it from the hub. I removed the hub by loosening the bolt at the top of the hub with a socket wrench. I removed the hub after removing the bolt. I removed the long stringy fabric by unwinding it and lifting up. that's all there is to it. Really simple. Everything went back together very easily. Only hard part is lifting the agitator up with enough force to free it from the hub.
Aug 10, 2012 | Hotpoint Washing Machines
Diplomat ADP 8322 - 11 Flashes. Will not go beyond the Rinse cycle.
There's never a good time for the washer to stop working correctly. If a washing machine's agitator isn't working properly, your clothes won't come clean.
The back-and-forth movement of the agitator is a main function in the cleaning process of your laundry.
If your agitator isn't working, it could be the agitator itself or broken splines in the assembly beneath the agitator. Either one is a relatively easy and inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
  1. Inspect the agitator for breaks. If the agitator is broken or cracked, you'll need to replace it. A broken agitator won't operate correctly, if at all. If the agitator looks fine but isn't moving, you'll need to inspect the plastic splines in the agitator assembly located underneath the agitator.
  2. Remove the agitator from the washing machine by first removing the fabric softener dispenser cap on top of it. This cap should either pull or screw off. It it's difficult to remove, you might have to pry it off.
  3. Unscrew the bolt beneath the softener cap with a socket wrench. Once you've removed the screw, try lifting the agitator out of the washer. If it doesn't easily lift out, loop a rope underneath one side of the agitator and over a broom handle. Continue looping the rope under the other side of the agitator and back over the broom. Using caution not to hit yourself in the head, pull up on the broom until the agitator comes loose.
  4. Replace the broken agitator with a new one. Snap the new one in place and secure the bolt underneath the fabric softener cap. Place the cap back on the agitator and you're ready to start washing.
    Check the plastic splines in the assembly directly underneath the agitator, if the agitator itself isn't broken. If the plastic splines are broken or worn down, this will keep the agitator from properly moving. In fact, it might not move at all. Replace the spline assembly with a new one and reassemble the agitator by reversing your steps to remove it.
Good luck and thanks for using fixya.
Dec 24, 2010 | Dishwashers
Ge whdrr418e4ww my agitator seems to have come loose
One stupid question on trying to get access to the nut to remove the agitator shaft. After I removed the fabric softener dispenser there appears to be a plastic cap between. I've tried everything I can to remove this piece of plastic so i can get access to bolt.. Am I missing something obvious?
Jun 11, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Clothes are still saturated even after spin cycle. I have to manually wring them out. What do you think is wrong?
It sounds like the plastic dogs under the agitator are broken.
Remove the softener cup
Remove the cap
Unscrew the bolt
Pull off the top of the agitator
Go to an Appliance Parts Store.
Mar 27, 2010 | Whirlpool LSR7333 Top Load Washer
Top agetator is not working what do i look for
well if the model number thats attached to this call is even close theres still 20 sub-models from ther. anyways your agitator sits upon a plastic drive bell, you can remove the agitator by pulling up sharply upon the agitator (sometimes a belt looped under the agitator provides a better grasping surface), then you can see and touch the drive bell, which is held in place by a 7/16th bolt.. that drive bell is indexed to the transmission drive shaft by splines that sometimes/often wear out allowing the agitator to spin sorta freely..
give that a shot and let me know..
have fun, and good luck,
ttfn
Jan 31, 2010 | Hotpoint VBXR1090D Top Load Washer
Anyway to remove agitaror to get stuck piece of fabric without tearing apart entire machine? Kenmore top loading washer
This is a simple procedure. Just follow these steps:
1. Remove the center post cap or fabric softener dispenser (if equipped) from the agitator by gently prying it off.
2. Under the center post cap locate the air gap plastic cap (if equipped) and remove.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the upper portion of the agitator (called the "auger") by lifting straght up.
5. Remove the lower portion of the agititator by grasping the lower flanges near the bottom of the wash tub and pulling straight up.
This will expose the transmission shaft and anything that may be lodged under the agitator.
Reassemble in the reverse order of the instructions I provided. NOTE: Make sure you only tighten the agitator bolt until it is snug. Do not overtighten as this can break the agitator or restrict its movement.
If you have any questions, please let me know. I hope this helps you.
Jun 25, 2009 | Washing Machines
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
Replace dogs
take the cap or fabric softener dispenser off the top of the agitator. under it should be a clear plastic cap with a little handle on it. take it out. under it should be a bolt (7/16) with a rubber seal under it, take it out and this will release the agitator and you will see the plastic dogs inside the agitator.
Aug 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator Dogs
Aug 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator Removal
Most agitators also have an air gap cap underneath the fabric softener cap as well. This is to prevent water from rising inside the agitator and getting to the drum bearings. Look closely under the fabric softener cap to see if there is another cap that you might have to remove. You can usually use a small flat tip screwdriver to lift the cap off. You will need a socket (with extender) and ratchet to reach the mounting bolt. As you loosen the bolt, you will need to hold on to the base of the agitator at the same time to keep it from turning. Now, not knowing what your agitator looks like, it may or may not have this set up (just a thought for you try). If there is no mounting bolt of any kind as you say, the type of agitator you may have is held on by plastic grips that snap on to a mounting hub under the base. Unfortunately there is no easy way I know of besides lifting straight out. You may have to rock it side to side a little while pulling up to get the clips to release. Normally, the problem encountered with this type of agitator is the clips wear out and no longer grip and it keeps falling off. Why do you need to remove the agitator? Just wondering because you didn't mention any problems. Good luck to you. I hope this helps.
Jun 30, 2007 | Amana ALW480DA Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
125 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
