Once in tech rep mode of np6025 canon and the new drum unit is in the machine....what are the steps to resetting the count? I just want to know before I go back to the customer
  • seggers182 Feb 05, 2010
    The model is a Canon np6025. i need the steps to reset the drum count. After putting in the new drum and hitting * 28 * I need the steps after that.
  • seggers182 Feb 25, 2010
    thanks, I appreciate technical information that applies to my model and brand. The other help I got wasn't even applicable to Canon.
  • 2,069 Answers
Please refer to this document for instructions.
Posted on Feb 05, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please follow the steps:-
Hit the utility/counter button.
Touch meter count.
Type the following on the keypad:
<STOP> <0> <0> <STOP> <0> <1>
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 03, 2010
Reset error m2
M2 -waste toner box need to empty.
Displayed to indicated that the Toner collect count of the consumables counter has reached the set count.To reset select Count in the Tech.Rep.mode and acces the Consumables screen.Select the count of toner collect and press the clear key to clear the count.Place the copier in the Tech.Rep.mode by pressing the following keys:Stop-0-Stop-1.
Dec 30, 2013 | Minolta EP4000/5000 CS/PRO Copier
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
We have a Toshiba 170F fax machine that is no longer under warranty. I need instructions on how to replace the drum.
the drum & its cover is one unit
just remove the toner cartridge & put it in the new drum unit cover
May 11, 2011 | Toshiba E-Studio 161 Copier
How do I change the pc drum on a di 2010?
Hi to replace the drum on the machine you will need to do the following
select the tech rep mode then counter-pm-pc life press the clear key to clear the counter value turn off the power. Open the right side door slide out the drum unit from the left and right side of the unit remove the four silve screws two at each end now seperate the top part from the bottom part the top part holds the drum and the bottom part is the developer unit and holds the developer
you can buy the top part as an assembly then reinstall the new drum to the bottom developer unit put back the four silver screws you took out earlier and then put the unit back into the machine
You should replace the developer if you are replacing the drum at the same time now the unit is back in the machine turn on the power select tech rep mode then function f8 and then press the start key ONLY PRESS F8 if you replace the developer
you will also need to go into tech rep mode counter pm developer press the clear key to clear the value
turn off machine wait ten seconds turn back on this resets the counter
Tech rep is normally user counter then stop 00stop 0 1 press one after the other
Jan 11, 2011 | Minolta DI-2010F Copier
HI THERE , I GOT ONE PROBLEM IN BIZHUB250B ERROR C2557 .. I PUT OLD DRUM,DEVELOPERAND I RESERT F8 AND RESERT COUNTER STILL ERROR CODE IS THERE , AND ALSO PUT NEW PARTS DRUM DEVELOPER, ATDC STILL THE SAME...
1.press the utility button
2.meter count and details button
3.enter tech rep mode: stop,0,0,stop,01
4.select tech rep choice mode
5.select printer tab
6.select atdc sensor gain
7.set value to 165
back out to the ready screen then power off then on the machine have done this many times and just fixed one today with the same problem
Nov 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Machine will not reset drum count
In the copier mode go into f7 mode and reset the drum or process unit count this should clear it
May 07, 2009 | Panasonic DP-150FX Laser Printer
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Di520 black and white copier toner collection box
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
Dec 30, 2008 | Konica Minolta DiALTA Di200 Copier
Need to know how to reset codes
To reset the life counters for the transfer roller & ozone filter you will need to enter the service mode.
To do this press utilty, meter count,details(if available), then stop, 0, 0, stop , 0, 1.
You should now be in tech rep mode, select counters then life.
Select the transfer roller/ozone filter button and press the C key on the keypad.
It should zero the life count.
Now press end, exit etc until you back at the copy screen.
Warning: Please do not reset or clear any other data within tech rep mode or you may inadvertantly affect the performance of you machine.
Hope this Helps.
May 05, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
k24674
jasbo
jasbo
