Question about Philips FR965DHT Receiver
Unit turns on for 2 seconds then goes off, standby light remains however
The Amplifier Has A short. Do you play at high volumes or may your speaker wires have crossed for a second or two or maybe hooked up or disconected while unit was on. Probably just needs a fuse unless circuts burnt before overload protection engaged!
Posted on Feb 03, 2010
2 Suggested Answers
Bulldog AV
  • 52 Answers
SOURCE: after turning ON the power/standby switch, the
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
Why does the standby light either remain on or fail to turn on?
Hi Alan, the standby light should be off when the unit is up and running and be on when the unit is powered off indicating that the unit is on standby, Thanks, JT
May 25, 2015 | Onkyo HT-S6200 7.1-Channel Home...
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Sony KDL-40S4100 Bravia LCD will turn on for like 2 seconds with picture and green power led, and then goes to flashing red standby led twice for a bit. Then I hear a
Mar 28, 2011 | Sony Televison & Video
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Mar 09, 2011 | Sony Televison & Video
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Nov 16, 2009 | Denon AVR-485 Receiver
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Projector shuts off sporadically
1. Pls check the airflow of the cooling of the projector, or just service the all unit.
2. As you told that the lamp life is 76%, Check the inner
reflector have shiny surface of dimmy, If not shiny, then replace
the lamp unit.
Enjoy
Viren
Jul 20, 2008 | Sharp XR-10X Multimedia Projector
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
Philips FR965DHT Receiver Logo
281 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
