Question about Hoover Nextra HNL 3166 Z Front Load Washer
Power getting to mother board but no power coming out of it?
  • Hoover Master
  • 3,463 Answers
The odds are it is the main board that is at fault, unfortunately, there is no way to test these.
Problem is, if you replace the board, then there cxould still be another fault which caused the board to fail in the first place.
Hope this helps.
Posted on Feb 03, 2010
Display ic motherboard
A> Check you Power all connection proper connected.
B> Check you SMPS power proper working or not.
C> If direct display not coming then sec option is external display card connect in mother board and check display come or not. if display come then you internal display cheap damage. If both option used or display no then you mother board problem.
D> Check you RAM, section if RAM problem then display no.
E> And finally one time mother board bios batter disconnect and few sec wait and re-connect bios batter. Remember batter disconnect before all power cut.
Thanks...
Aug 26, 2013 | Dell OptiPlex Computers & Internet
I have a Dell Latitude D610. The battery was dead (got the 4 blinking amber lights and the green light flashing once, then cycling), so I replaced the battery. The new battery has the lights on the bottom...
From the description, sounds like you have two failures, both concerning the mother board.
1. The connection to the motherboard for the battery is no longer good. Replace the mother board. The points of failure that you have given so far and has not fixed the issue. Battery fully charged, seated well, no change, mother board.
2. Laptop will come on with AC adapter attached but will not boot up; mother board. There is a built in test that you can run, from a powered down state press FN + Power button, this puts this into a diagnostic state. If it does not go into this diagnostic; mother board. The diagnostic is stored in the BIOS, which is a part of the mother board.
3. If the diagnostic runs note any error codes that it gives. They will be in the form off XXXX-XXXX or XXXX:XXXX, where the X's represent a letter or a number. These can be used for further trouble shooting.
Jul 24, 2010 | Dell Latitude D610 Notebook
WHERE TO PUT HARD DISK POWER PIN IN MOTHER BOARD
The hard disk power cable is to be connected to the power cables that comes from the SMBS. And only the data cable is plugged on to the Mother board
Mar 11, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No power leds. My Ac adapter is new with the right voltage coming out. I have to keep on unplugging the power cord then the green light comes on my Dell Inspiron 1300....I took the Laptop apart and solder...
You will probably find, that the power Jack on the Mother Board has fractured the solder joint, this is a common problem. You may have to get it to a shop.
Mar 08, 2010 | Dell Inspiron 1300 Notebook
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Jan 10, 2009 | Refrigerators
Intel D865GSA Board won't power up?
check your ram and processor then send your board to chip level servicing
Oct 13, 2008 | Intel D865GBF Motherboard
How to take an acer apire 9410-2028
You'll have to remove the mother board to fix this. Basically, remove the keyboard & touchpad. You will see the mother board at that time. Remove whatever else is necessary to get down to the mother board. Hint! Keep track of what screw comes out of what hole. You'll need to know that for reassembly.
Ron-
Nov 11, 2007 | Compaq Presario Notebook
Hoover Nextra HNL 3166 Z Front Load Washer Logo
145 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
