Question about RTO Forklift and Pallet Construction Vehicle
Trany leak I have a DAEWOO,model 6C255-3 forklift. This unit has an G5T1,trany.my problem is on cold start runs,oil spuse out the dip tube that is slightly airated. It's not over full,On loss of oil in this manner movement is delayed . To regain proper travel lost oil must be replaced .APX.1lt.after warmed this doesn't happen.
How do u top gearbox oil up on a automatic clio 51 reg
For vehicles without ATF filler tubes and dip sticks accessible in the engine bay, the ATF needs to be pumped in from the side of the transmission and from under the car. There is a specific filling procedure that must be followed. If your particular model has no Auto transmission fluid filler tube with dip stick in the engine bay this is what must be done. If unsure on your particular model then check your owners manual or contact the dealer service people.
If your model has no engine bay ATF filler tube I suggest you get the dealer to do it for you or a transmission business that knows these transmissions and will not overfill it. The vehicle needs to be up on a lift and perfectly level in cases when fluid is required to be pumped into the Auto Transmission from under the vehicle.
These transmissions are sealed units and if fluid needs to be added then you will have a significant leak that needs to be attended to. Running the transmission with low fluid which requires adding to will result in expensive damage to the the unit. If you have a model with no engine bay transmission filler tube and dip stick to check the auto fluid level you will have no idea how much fluid is being lost if you have a leak.
Nov 20, 2015 | Cars & Trucks
Hi there i just noticed the little kettle oil warming light which goes on and off...what can the problem be and where is the oil pressure switch located 99 Daewoo Lanos 1.6?Car not yet due for service.Many...
Check to see if you have enough oil in the engine, With the dip stick-before running engine while the motor is cold check oil level and add as needed.
Mar 19, 2015 | 1999 Daewoo Lanos
I have a ZTS 7500. How do you know if your dip stick tube is leaking?
Clean off engine with brake clean and then start, while someone watches front of engine. And yes the dipstick tube may be the leak. This link should help. http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709063.pdf
Apr 23, 2014 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Where do I add Transmission fluid on a 95 ford Probe??
So you know, I am not insulting you. I don't know what you know or what you don't know. From your symptoms, I'm confused. If you pulled the trani pan down and the trani dip-stick still read "Full", you pulled the wrong dip-stick. Your transmission takes Mercon and you will need a narrow funnel that will fit inside the trani dip-stick tube. Follow the dip-stick tube all the way to the bottom and verify that it goes to the transmission. When you pulled the trani pan down you should have four or more quarts empty into your drain-pan. Until you can confirm that the the trani is properly filled, don't continue to use the car. Running the engine while the trani is empty can damage internal componants. If you have any questions, please write back, good luck.
Apr 13, 2014 | 1995 Ford Probe
Oil leak
If the hose comes out the top of the transmission, this is the transmission vent line.
Make sure the line doesn't "dip" anywhere alone it's run, causing a low area where residual oil would "pool", then blow out under pressure.
Also, make sure transmission fluid isn't over-filled.
Mar 20, 2014 | Harley Davidson XL Sportster 883 Hugger...
How do you check and add transmition fluid on a 2006 VW Passat
The best way is on a lift, the engine must be warm and car level, with the motor running remove the plug on the bottom of the trany pan, oil should leak out a little, this means its full if not then on top side of trany remove the fill pull cap and add from there until it starts to run out of the plug, theres a long tube in the pan and oil will only run out when level is higher than the tube. hope this helps.f781d2f.png75884bb.png1d36d6b.png
Oct 08, 2010 | 2006 Volkswagen Passat
Water starts of hot but then starts to get cold.
You need to verify that you still have hot water. Sounds like you're running out.
Sep 28, 2010 | Home
Transmission dipstick location
the dip stick is located in engine compartment if you stand in front of car with hood open the dip stick is to your left on side of trany, if this car is stick shift and not automatic then theres no dip stick its checked from side of trany by removing a plug and fill until oil runs out a little a lift would be the way to check it, the car must be level
NOTE; some models have a tube with dip stick and some a cap that unscrews on top of trany and when checking fluid you dont screw in just stick in hole to check level when done then screw back in and tighten,heres a diagram to help you find it.c083006.gif
Aug 25, 2010 | 1991 Honda Civic
Lot of smoking from under the vehicle while moving. slow in making gear clicks
You may have a trany oil leak hitting the exhaust system and you may be low on trany oil. check the trany oil level, this is done on level ground with the engine warm and running pull dip stick clean and reinsert then remove and check the level, start with that.
Apr 19, 2010 | 1992 Ford Explorer
Where's my dip stick?
theres no dip stick ,there are to plugs on trany one on the bottom to drain and one on the side,remove the side one oil is full when it starts to flow out,but caution dont star removing bolts unless your sure could cause trany damage on some tranys,go to a oil and lube shop have them lift truck and check takes 5 to 10 minutes,good luck.
Nov 01, 2009 | 1998 Mitsubishi Montero Sport
RTO Forklift and Pallet Construction Vehicle Logo
53 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
