Question about LG DLE3777 Electric Dryer
How do you remove the top/front of dryer?
When i turn on the dryer it makes a humming sound but doesn't turn.
i am guessing that there is a problem with the belt. would like to see inside but i don't want to remove any unecessary parts.
    Novelist:
  • 127 Answers
Like a lot of the newer "energy efficient" models there is no longer an easy way to get to this stuff.
There are screws on the rear of the top that once removed will allow the top to slide back a little, then lifted off to expose the innards of ur machine. The front of the dryer has to be removed to gain access to the drive train. Some of these LG "laughing greatly" machines have to have the front electronic controls removed to be able to access the top screws that attach the front of ur dryer to the chassis, lucky you. Once you gain access to the screws for the front of ur unit, disconnect the door switch harness, pivot the front out slightly at the top and lift, the bottom is retained by clips. Then you can view the inner front support, rollers, belt, tensioner etc..
best of luck, and have fun,
ttfn
Posted on Feb 03, 2010
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
Samsung dryer hums but the drum does not turn
It sounds to me like the drive belt that goes around your dryer tub has broken.
images?q=tbn:and9gcqu5itfzbd0xyagva6nfwjbc486ekglruzljwmfemwgndlj-mg5tw
The back of the dryer will need to be removed to gain access to the problem.
Oct 27, 2012 | Samsung DV448AEP 7.4 Cu. Ft. Electric...
Dryer is plugged in but won't turn. Only makes a humming noise like the motor is on. I took the back panel off but don't see fuses/breakers.
It sounds like the belt has come off the dryers drum that spins around. Remove the top & the front panel to see. Sears sells the belt along with a idler pulley which should be change with it too. The bearing in the pulley to make the belt break or come off when the bearing seizes up
Dec 26, 2010 | Dryers
DRUM WON'T TURN MAKES A HUMMING SOUND WHEN U TURN IT ON
Looks like you have a broken belt. What I like to do if at all possible is get that dryer outside where I can clean it up real good. I also like to check the vent82109c9.jpg and make sure it is clean. Then I like to clean all areas out where lint accumulate. I remove the filter and 2 screws at the top then I pop the top and remove the screws holding the front.80a54c2.jpg Then I raise up on the front panel to keep from breaking the clips. Get the drum out and do a good cleanup. Check the rollers and wheels and when I go to replace the belt I make sure it ain't twisted. It helps to have a partner hold the drum while you connect back the idler.3fae00c.jpg Nothing to it.
Manual and more here.
Jun 10, 2010 | Whirlpool LER4634J Electric Dryer
My dryer is a frigidaire, and when i turn it on yo...
The humming is the sound of the Electric motor that drives the drum to spin
You will need to remove the top & the front panel to repair.
First just remove the TOP panel only for inspection
On the top's rear side you will see two small brackets with screws in them. The brackets attach to the Top & the rear panel to secure the top on
Remove these two screws
Now go to the front & pry each front corner up with a flat head screwdriver between the top and the front panel
Spring steel retainer snaps holds that into place and will not break when prying upward
Remove the electrical connectors and mark them with tape if wanted were they connect to for reference
Now look inside the dryer and you will see the drun and the belt should be around this drum. If not replace the belt. You will need to remove the front panel side screws to remove the front panel to remove the drum. The belt tensioner hhas a roller on it too which will need replacing.
Reverse procedure to install
May 20, 2010 | Dryers
Model DE 106, eletric dryer. Will not start. Turn
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 12, 2009 | Dryers
Dryer hums
the motor could be bound up or going out on it. you would need to take it apart and see if theres something binding it up
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Series 80 kenmore washer..doesn`t spin..
Make sure belts are still atached. Belts are relatively inexpensive and eazy to replace yourself.
Jan 14, 2008 | GE WSM2700D Top Load Stacked Washer /...
LG DLE3777 Electric Dryer Logo
400 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
