Question about Keurig Coffee Makers & Espresso Machines
Water does not seem to empty into keurig single coffeemaker; It
Water does not seem to empty into keurig single cup coffeemaker; It just makes noise and then shuts down. every now and then you can get the machine to make a cup or two with hrs inbetween use.
  • Anonymous Mar 17, 2014
    can not get the coffeemaker to stop filling the cup and it overflows and keeps running until the water resevoir is empty
Water is not getting hot how to trouble shoot
Posted on Feb 03, 2010
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
I put milk in my Keurig and now it won't work...i think the milk burned
..wait..you mean you poured actual milk into the water reservoir on a Keurig coffeemaker..?
That's not good.
What prompted you to do that?
My advise would be to boil water in a kettle, adding about a half-cup of regular vinegar. Pour this into the coffeemaker and let it run through a cycle with just the hot water/vinegar solution. Next, run plain hot water through it.
Hopefully, this will help with flushing out any/all milk that's clogging the coffeemaker. You may have to do this several times to remove the milk residue..milk will cling. (and will start to smell foul..which may or may/not attract insects) so don't ever do that again!
Phoning Keurig Customer and product support may assist you further. They are generally very helpful with all inquiries and issues.
Keurig single-cup coffeemaker
http://www.keurig.com
(866) 901-BREW (2739)
Jul 12, 2012 | Keurig B30 Mini Coffee Maker
Keurig coffee maker makes loud noise single cup brewer. Make loud noise prior to brewing.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 20, 2010 | Keurig B60 Coffee Maker
Keurig coffee maker sucks in water and spits it back into the reservoir instead of making a cup of coffee
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
l;]p]0
Nov 17, 2010 | Keurig B100 Coffee Maker
I have a Keurig B60 coffeemaker. When making a
Descale yes you should every 3 months. Use 48 oz. of white destilled vinager and follow the instructions in your use and care guide
Mar 14, 2010 | Keurig B60 Coffee Maker
B100 putting out very little water, reservoir is full
bye descaling product for the coffee maker not vinegar put descaler in machine fill with water start leave it running for 10 seconds close it for 15 minute start it up again repeat untill empty after its empty fill it with water run it untill empty repeat again descaler is acid so you need to rinse very good try it out thanks pierre
Jan 11, 2009 | Keurig B100 Coffee Maker
The machine seems not to be working well
I had very similar problem and found the fix here.
Did you try the reset process? Place an empty cup, insert a coffe pod, press and keep pressing the "Lungo" button until the cup is filled as desired then release it. Next coffee, just press once, it should be now set at the desired level.
Jan 03, 2009 | Nespresso C100B Essenza Single-Serve...
Water in Keurig single cup coffeemaker was very low--started it too soon & ran out; added water but still won't flow more than a drip or two
Make sure there is water before you do all this. Unplug it from power wait 1 minute plug it back in. Open and close the coffee holder, wait a few seconds, press any of the brewers. Basically reset the whole system.
Nov 11, 2008 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
159 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
