Loewe xelos 5270 zw. picture becomes green
Loewe xelos 5270 zw. after tv has been on for maybe 10 minutes or more the tv picture becomes dark and mostly green in colour.
  • 1 more comment
  • tinapb Feb 03, 2010
    thanks, i'll try your suggestions. if they dont work am i looking at buying a new tv or should/can i get it fixed?
    thanks again
  • tinapb Feb 07, 2010
    the set is 6 years old. is ok then green and dark - then it returns to normal.
    thanks
    yes - thank you
  • 3,230 Answers
Well most probably the cathodes have worn out. The emission material on the surface slowly becomes inactive. Usually you see one color go first, then the others. At the same time you will observe a loss in sharpness, because a larger cathode area is being used, giving a bigger spot. Rejuvenating is done by applying a (too) high filament voltage, in order to bring new emission material to the surface. It will not work for long and there is the risk of burning the filament wire for good. You won't be able to see it without taking the back off, but your CRT (picture tube) filament is going out. You could try to wriggle the CRT Tube Socket back on a little tighter then watch it for a while again. Then again, it may also be that for some mysterious reason your VG2 voltage has dropped below spec. A too high VG2 voltage will cause a smaller cathode area to be used, leading to a sharper picture but accelerated cathode wear.
Please post comments for more help or information........
Good Luck!!
Thanks
Posted on Feb 03, 2010
  • 1,476 Answers
If your set is over 12 years old I would say it could be having picture tube problems. It could also have a bad component in the video drive circuit. The picture tube could be checked by a competent shop to ascertain that the tube is OK. If it is the repair of the problem causing the loss of drive should not be difficult or costly by a reputable shop. It does sound like a problem which would be beyond your capabilities. Find a reputable shop. Let me know how you make out or if I can be of any more help.
hardrocko
  • Kim Yearick
    Kim Yearick Feb 07, 2010
    I can't believe the fix I advised wouldn't work but yes if you adjust or have someone adjust the screen drive and the unit still looks dark then your CRTs are done. They are not worth replacing these days and yes you would be looking at a new unit. Let me know.
    hardrocko
  • Kim Yearick
    Kim Yearick Feb 08, 2010
    6 years would be premature for a tube failure. Obviously the green is going into accelerated drive compared to blue and red. You could have a dirty screen drive control or a bad focus divider block. You will probably need a qualified tech to check that out for you. Give it a try and let me know how you make out.
    hardrocko
Why is my colour TV (10 year old Loewe Xelos) only showing Black & White?
Its system settings should be checked. Refer its user manual for details. It it is multisystem one, set the system settings to 'Auto;.
Feb 22, 2013 | Loewe Televison & Video
Loewe Xelos
just replaced bad capacitor in the power supply usually leak or bulged to its casing.
Jul 18, 2012 | Televison & Video
Loewe Xelos TV 7 years old - screen image has colla_psed at the sides so appears distorted viz )_( shape. Is it a write off?
look for an square transformer near the LOT,underneath the transofrmer there is a resistor that can be defect.Measure al capacitors in East West circuit for bad capacitance.
Jul 27, 2009 | Televison & Video
Tv beginning to flash green with horizontal white lines
From your description it sounds like a bad picture tube. The lines are called retrace lines. There is a small chance that a component on the small board that connects to the neck of the tube may be bad. Without model number information it is very difficult so say further. Some picture tubes can be re-jeuvenated with the appropriate machine ( at a TV repar shop)
If you feel adventurous and are careful you might try GENTLY tapping the neck of the tube and see if picture improves/goes out. If the tapping does change the picture it is definitely the tube
Mar 12, 2009 | Loewe ARC332 32" TV
I have a loewe television plasma it reads a planus 4781 zw serial no Dl253 i dont have a manual and i have no channels i need the settings so i can re program the tv can u please help
Thanks for getting back to me I have fixed the problem i just went through the whole menu of the television and worked it out for my self thank you for returning my email
Dec 11, 2008 | Loewe Table PLA530 30" TV
New remote control unit.
You should try replacing the remote by buying a Logitech Harmony remote which you can then program to work your Xemix. It works really well for me. Alternatively if you can't get a dvd remote, try to get a TV control for a Loewe Xelos TV which has a DVD mode just for the Xemix dvd player.
Dec 07, 2008 | Loewe Xemix 5106 DO DVD Player
My T.V SWITCHS OFF AFTER 1 MIN BEING ON
there must have been a automatic off timer set on ur tv. check the self off timer settings
Feb 23, 2008 | Televison & Video
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Electro Med Services...
