Question about HP Officejet Pro L7680 InkJet Printer
Printing Shortcuts under Printing Preferences has stopped showing double-sided as an option. It's no longer listed. Doublesided was there and working fine until now.
  • admin593 Feb 10, 2010
    Your reply did not address my problem. My printer has auto doublesided printing as a feature. I should not have to print odd pages, then even pages. It worked fine when first installed but now the printing options list does not show double-sided any more.
    My HP L7680 printer has doublesided/duplex printing as a feature. When first installed, under printing options it listed double-sided; when selected it printed the whole doc double-sided automatically. Now print options does not have double-sided in the list! How do I restore that?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If your printer is not showing this feature then please go to print dialog box and click on properties->click on the Printing Shortcuts tab and select Two-sided (Duplex) Printing from the drop-down menu. Now select Automatic from the Print on both sides drop-down menu.
After performing the above steps if still the issue is not resolved then you’ll need to download and installed the drivers afresh.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 10, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please chek this link and download the pdf file to set the particular option..
http://www.anu.edu.au/anugreen/files/511_double_sided_printing.pdf
Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 03, 2010
Interact s605 printing upside down
You can change the settings under printing preferences, just follow the steps below:
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Navigate to:
Advanced tab > 2-Sided Printing area > select On
Note: To use the settings defined in the printer, select Use Printer Settings.
4 Select either the Side Flip or Top Flip option. Side Flip is the setting most often used.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
To return to single-sided printing, navigate to:
Advanced tab > 2-Sided Printing area > select Off
Sep 01, 2012 | Lexmark Interact S605 Wireless All-in-One...
Bizhub 211 double sided printing inactive
It was the same problem. To enable drop down menu open "Device Option" tab where you will see list:
Duplex Non Instaled
Tray2 Not Installed
Tray3 Not Installed
Just double click on "Duplex Not Installed" and it will changes on "Installed" and Double sides drop down menu become active.
Jan 20, 2012 | Konica Minolta bizhub Office Equipment &...
Photos come out totally blurred with colors mixed. Happens on all sizes of paper (photo quality).
  1. Make sure that there is letter, A4, or legal unused plain white paper in the input tray.
  2. Touch Setup on the display.
  3. Touch Tools .
  4. Touch Self-Test Report . A self-test report prints. Figure 1: Self Test Diagnostic Pagec01154260.png
  5. In the Print Quality Pattern section on the test page, look at the color blocks for any lines. Figure 2: Print Quality Patternc01154261.png
  6. If there is no color bleeding in the Print Quality Pattern color blocks, print a document to determine if the issue has been resolved.
If you have completed all of these steps and are still experiencing a problem, continue to Step three. Step three: Check the paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
If you have completed all of these steps and are still experiencing a problem, continue to Step four. Step four: Check the printer settings
  1. In the software program you are trying to print from, click File and then click Print . The Print window opens.
  2. Make sure that your printer is selected and then click Preferences . The printer Preferences window opens.
  3. Click the Printing Shortcuts tab.
  4. The Printing Shortcuts tab lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab:
    • General Everyday Printing
    • Photo Printing-Borderless
    • Photo Printing-With White Borders
    • Fast/Economical printing
    • Presentation printing
    • Two-sided (Duplex) Printing
    NOTE: These general printing shortcuts have pre-selected settings.
  5. To change the settings from the ones that are available on the Printing Shortcuts tab, click the Features or Color tab. Options on the Features or Color tab include:
    • Print quality : If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches your paper type exactly, select it rather than Automatic.
    • Paper size : Make sure this matches your paper.
    • Print in Grayscale : Print a document in shades of gray.
    • Orientation : Specify how the document is positioned on the page.
    • Paper Source : Select the tray that you want to use for printing.
    • Two sided printing : Print on both sides of the paper.
    • Color Management : Specify the color space that the printer will use to interpret image data.
    • Pages per Sheet : Specify the number of pages of the document to print on each sheet.
If you have completed all of these steps and are still experiencing a problem, continue to Step five. Step five: Clean the printhead
NOTE: Do not clean the printhead unnecessarily because this wastes ink and shortens the life of the ink nozzles on the printhead.
  1. Make sure that there is plain white paper in the input tray.
  3. Touch Tools .
  4. Touch Clean Printhead . The HP All-in-One cleans the printhead and prints a test page.
Step six: Service your productIf you have completed all the steps listed above and are still experiencing a problem, service the product
Dec 07, 2010 | HP Photosmart C8180 All-in-One InkJet...
Laptop running XP desires to connect to desktop running windows 7-driver needed for HP 2840 color laserjet before connection to windows 7 desktop-is driver put on laptop or desktop
There is no driver for win 7, although if you are running on windows 7 32bit there is a work around. Download the software for windows vista 32 bit for the 2840.
Jul 13, 2010 | HP LaserJet 2840 All-In-One Printer
Can not print pdf double-sided on Kyocera FS C5020N
surprised you actually got doublesided... ok... in a situation like yours... I would update to the latest adobe reader... that has been known to give you issues with printing.... and if it continues call kyocera support... this sounds like an issue they would want to work on...
Oct 05, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Duplex still has problems printing double sided.
Hi, Please find the work around steps to resolve duplex printing issue in Windows Vista. Please the send the *.gpd files to the cu via mail before doing the steps. Duplexer Printing for Windows Vista Troubleshooting steps 1.start-all programs- accessories ? cmd -right click-run as administrator 2.Stop the Spooler service - Type net stop spooler 3.Change current directory Type cd windows\system32\spool\drivers\w32x86\3 4.Backup the old gpd files - Type copy hp*.gpd *.bak 5.sent the zipped file to customers email address through astro and then download the file to customers desktop 6.extracted the files from the zipped folder and then pasted those files to windows\system32\spool\drivers\w32x86\3 7.Remove old BUD file Type - del HP*.bud file 8.Restart to spooler service - Type net start spooler 9.checked under printing preferences if the both sided printing is selected as automatic and then tried printing a two page document 10.checked whether its printing or not. 11.) Start-Control Panel- Printer & Faxes- Right Click On the printer -Properties-Device settings-Disable the manual Duplex printing-Click on Installed Two sided printing-click on apply & ok. 12) Then Go to Right Click on the Printer-Printing preferences-Paper quality-Select Two Sided Printing from the top drop down list where its showing What do you want to do? 13) From Print on both sides-Select Automatically from the drop down list. 14) Try to print on both side check whether its working or not.
Sep 18, 2009 | HP PSC 1510 All-In-One InkJet Printer
Driction of dobulesided printing. Suddenly the front side prints correctly and the backside prints in revese direction.
To adjust these controls open you start menu, then control panel. Click on classic view, then click into printers.
Right-Click on your Printer and select properties from the grey menu.
Select Priniting Preferences as in the picture.
On the printing shortcuts menu ensure you have double sided printing selected then:
Then got to the advanced tab and click on the page order selection, once you click it a list will pop up with Front to Back and Back to Front listed. Click the one you want and then OK out of both windows.
Hope this helps FixYa,
Chris
May 14, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Duplex printing in HP 2420dn
I had the same problem. It was due to incorrect properties in the printer settings.
  1. Go to Start >> Printers and Faxes
  2. Right-click on the HP 2420 printer and select Properties.
  3. Go to the Device Settings tab.
  4. Under Installable Options, set Duplex Unit to Installed.
Also, make sure that the Printing Preferences are set to Two Sided Printing:
  2. Right-click on the HP 2420 printer and select Printing Preferences.
  3. Go to the Printing Shortcuts tab.
  4. Select the Two Sided (Duplex) Printing option.
That should do the trick.
HP - please change your setup so that this is set by default!!
Brian Z
Mar 10, 2009 | HP LaserJet 2420 Printer
Hp officejet pro l7680
To solve this problem, you need to set the mirror image to 'off' under the advanced tab of the printing defaults and under the advanced tab of the printing preferences buttons. We had this problem for some time and since doing the above this has stopped.
Steve
Oct 23, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Deskjet 9800 will not print both sides
Yes, there should be a compatible driver for windows vista on their deiver page.
If there isn't you must buy a new printer.
Apr 19, 2008 | HP DeskJet 9800 InkJet Printer
HP Officejet Pro L7680 InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
