Question about Yamaha HTR-5830 Receiver
Is HTR5830 compatible with Bose Acoustimass 10 speaker surround sound system. We have no sound coming from rear speakers
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Posted on Apr 14, 2009
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Posted on Apr 28, 2009
  • 814 Answers
SOURCE: Yamaha HTR5830 shuts down when any front panel button is pushed
You are having a component failure problem in the switching circuit. This unit should be taken in for service. Since it is going into the protection mode on any switch operation the failure is serious and needs to be repaired before it causes more damage to the receiver.You can call this number to find a Yamaha service center near you. 1-800-492-6242. You can also go to the www.yamaha.com website. go to the support section and put in the model number of your receiver and check out the frequently asked questions and troubleshooting sections to see if someone else has had this problem and had a repair solution printed. I hope this helps you with your problem
Posted on May 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: 4 ohm speakers on Yamaha HTR 5540
Model number of the Lux? The only unknown to me regarding the answer is if the Lux speakers are designed for non-Lux attachment. If there are molded connectors on their leads I would be cautious as that is usually the manufacturer's subltlke clue that you really don't want toi mix them with other makers. If they're bare wire I think you're ok.
The impedance selector on the receiver supports minimum 4-ohm front and 6-ohm center and rear, so you'd be marginal on those last two, but barring excessive high volumes I'd think it would work. The powered sub is supported and its impedance spec is irrelevant.
Just curious, is this an upgrade in electronics? From what?
Posted on Feb 24, 2010
Testimonial: "Thanks for the helpful advice. I'll watch out the high volumes for rear speakers. the model number for Lux Audio is LUX-8500. yea the leads are bare."
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
Better sound through bose speakers?
If you have the money to plunk down for a Bose Acoustimass home theater speaker system, I'm sure you will be quite pleased. Of course, as you indicated, appropriate placement of the speakers is important. Still, I'm sure you will find that a properly placed Bose Acoustimass speaker system will fill your room with high quality sound, substantially better than Onkyo's stock speakers placed equally well.
I own a Technics home theater system, which I initially purchased to use in my family room. Yet, when I listened to a Bose Lifestyle system (powered by Bose Acoustimass speakers), I could have nothing less. The Bose system went in the family room, where everyone could enjoy it. I put the Technics system in the bedroom, where it is rarely used.
Jan 09, 2010 | Onkyo HTR500 Receiver
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Front Speaker not working
Yes, ur setting needs to be changed. On fliping the settings u will realise in one of the modes mostly the surround mode the speakers will work.
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | Bose?® Acoustimass?® 10 Series IV home...
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Aug 28, 2008 | Bose Acoustimass 15 System
Yamaha HTR-5830 Receiver Logo
79 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
