Question about Pacific Play Tents Train Station
Putting it together
No plan came with it on how to put it together
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
Ok these are tricky, so what you need to do is check your poles and connectors. You should have long poles and assorted connectors.
A bit of mathematics and you'll have it done in no time.
Ok lay out the poles and sort into longs and shorts.
Sort the connectors into 2 pole connectors (straights) and 3 pole connectors (three way)
Now check the angles on the three way connectors, sort them into groups. some should be slightly angled, these are the roof connectors and the others ones are 90 degrees and or more squarish these are the floor corner connectors. There should be 4 floor corner connectors and There will be two connectors that fit onto the end of roof front and back of the tent.
Sort out your poles and work out how many you need for each dimention. Basically your tent is a cube with a triangular prism on the top so you will need enough poles of even length to make the base and top bit of the cube and then even lengths of poles to make the upright sides of your cube. There should also be 4 four way connectors for attaching the roof. the top of you cube is the base of the triangluar prism.
Hope this helps. TIP once you get this together, MARK the conections with NUMBERS EG: 2 / 2 / 2 one number on each bit (the connector and each pole that is attached to it), this way when you pull it apart you can reconnect it much easier later on.
Posted on Feb 03, 2010
Tecumseh 20 hp tvt691 only runs on full choke
Sounds like your fuel jet is plugged. if you have a fuel cup on the bottom of your carb remove it and clean it out real good.The fuel jet should be the little screw tat holds the cup on Take it out and blow it outwith an air compressor or put a real fine wire through it if you do not have air pressure. You should be able to feel air if before you put it together you blow through it.
Might be a good plan to dump your old gas out and make sure your fuel tank is clean and put fresh gas into it.
A large percentage of when the engines have to be choked all the time the jet is plugged or partly plugged. Do not mess with the float when you take the bowel off or you could have other issues to get it put back together properly.
Aug 21, 2016 | Tecumseh Garden
Battery plan
Hi, Urusk10
It's better to put external uninterruptible Power Supply (UPS) machine to double your power back-up. for hardware plan.
For software power plan on the windows base operating system.
Click control panel > power options. inside power options properties you can see three the power plan you like.
Oct 24, 2011 | Gateway ID49C07u Notebook
Dell E1505 Intermittent display loss
When you click on Power Options, the power options screen will open. Here you can select a power plan, change plan settings.
When you click the Change plan settings option below any of the listed power plans, the Edit Plans Setting screen will open allowing you to change when the computer should turn off the display and when to put the computer to sleep, as well as the brightness setting of the display.
Turn off the display = Never
Put the computer to sleep = Never
Jan 07, 2010 | Dell Inspiron 6400 Notebook
My sun has disconnect board in the box and y have not plan for connect
Look your motherboard model up on the Internet and type in diagram. It will tell you what is what and where to put the pieces back together.
Nov 29, 2009 | EPoX (EP-4SGM8I) Motherboard
Hansgrophe kitchen Allegro Gourmet instructions to hook up. No instructions included in box. Please email hook up guide to vpmeyer@sbcglobal.net
I jjust started putting things together, and, put it in the counter top the way it looked like it would work. I had a hard time believing that there was no instruction sheet showing where each washer or grommet was supposed to go. Very poor planning on the part of the manufacturer as far as I am concerned. It seems to be working fine, but, I'm just very dissatisfied with the lack of even a picture showing what part went where.
Jun 19, 2009 | Hansgrohe Plumbing
Printing large sheet on small pages and piecing together.
is your building plan is an image ? if the answer is yes,
you can save the image, than you can print it from excel.
hope this help...
Mar 10, 2009 | HP Office Equipment & Supplies
I ordered a Graco Lauren convertible dropside crib 4-in-1. It did not come with instructions and I need them to put it together. Please help.
If you send your email address to mqwe1919 at hotmail dot com, I'll scan my directions and send them to you- unless you plan on getting a non-dropside crib, with the problems that have been reported.
Feb 25, 2009 | Graco Lauren Crib
Repost
the magnet will look like a flat piece and round , but small enough to fit in the center of the white piece. it could of came off and is now stuck to some metal inside the unit.
here is another example of how the magnet is placed and how the pieces fit together
I will upload some more pics in a second , I'm trying to find one that is just like yours
Oct 18, 2008 | Audio Players & Recorders
Pacific Play Tents Train Station Logo
289 people viewed this question
Top Pacific Play Tents Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Pacific Play Tents Toy Expert? Answer questions, earn points and help others
