Question about Frigidaire Kitchen Ranges
Lost manual for self-cleaning 30" slidein gas range. Need to clean it. Please give directions.
  • 3,230 Answers
Well you can please follow the below steps -
1. Clean the Frigidaire's control panel. Mix a mild soap solution using standard dish detergent and hot water in a bucket or dish. Gently grasp each plastic knob on the stove's panel and pull away from the panel to pop them off their metal shafts. Wipe each knob with the hot cleaning solution and a rag. Wipe down the actual panel. Avoid dripping soapy water into the exposed knob holes around the knob shafts. Replace the knobs after cleaning the panel by pushing the knobs back over the knob shafts. 2. Wipe down the painted metal surfaces of the Frigidaire stovetop. Frigidaire recommends using a homemade cleaning solution consisting of equal parts white vinegar and water. This cuts through grease and grime without eating away at the stove's paint. Dampen a soft cloth or sponge in the solution and wipe all painted surfaces with the vinegar and water. Wait 10 minutes for heavily soiled areas before wiping with a rag moistened with fresh water.
3. Use plain soapy water to clean any decorative chrome or stainless steel trim. Heavily soiled chrome or steel can be cleaned using a commercial stainless steel or chrome cleaner. Rinse thoroughly using a wet sponge or rag. Leaving soap or cleaning solution on the metal may result in dark blue stains once the metal heats up during standard stove use.
4. Clean the gas grates and burner heads. Remove them from the Frigidaire appliance by pulling them out of their recessed grooves on the stovetop. Scrub with a sponge and hot soapy water. Soak the pieces if they are caked with burnt food and debris. Place in a gallon-sized bucket and fill with water. Mix in 1/4 cup ammonia and allow the pieces to sit in the solution for 30 to 60 minutes. Remove, rinse and scrub with hot soapy water.
5. Dry the gas grates and burner heads with a dry rag. Replace on the Frigidaire stovetop. Resume use of the stove. Please post comments if you need more help or information......
Good Luck!!
Thanks
Posted on Feb 03, 2010
I need the instructions for fridgidaire gas range CFGF3017LW self cleaning as I have lost the instructions
Hello Sylvia Fairbank - I found the manual on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. If for any reason you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Jan 23, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Instructions for operating the self cleaning electric oven of General Electric? ?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 26, 2011 | GE Profile 30" Self-Cleaning Freestanding...
Lost directions on my stove. How do you clean the self cleaning oven. Its a ge electric range
Their should be a knob on it that says self clean or just clean set and you need to lock the door shut, when the cleaning is complete the door should unlock automaticly.
Nov 21, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Lost instructions - I have my oven cleaning how
Typical oven self clean cycle is 3 hours. Oven needs to cool down to under 550 degrees before door will unlock. Download a use and care manual at http://www.geappliances.com/service_and_support/literature/
Nov 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lost my manual. how do i clean my self cleaning Gemini double ovens
would need the model #, but generally, the top oven is manual clean. To clean larger oven, press clean, then up or down next to the timer to determine how long you want the self clean to run.
Nov 15, 2009 | Maytag Gemini 30" Self-Cleaning...
Jennaire broiler doesnt work on slidein range after using self clean oven. Its only 14 mo. old
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Jun 10, 2009 | Jenn-Air JES9860 Electric Kitchen Range
How to use self cleaning
I would just use easy off the self cleaning is ok but not really reliable
Dec 06, 2007 | Tappan TGF657 Gas Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
