Question about HP Pavilion m7480n (882780389410) PC Desktop
I believe the power supply is out. A green lite coms on in the back, but the fan motor does not turn.
    Sergeant:
  • 275 Answers
Not sure of your brand but if you are handy you should be able to take care of this yourself or bring it into any local shop.
If you do this yourself, unplug unit, open the case, disconnect wires, I label their locations with tape or a marker for re connection, take the unit in to match it up and get replacement. My problem is usually the fan since I don't use the old xp model much. They aren't that expensive, maybe $30 or $40.
With anything like this, if it sounds too much, take it in. Also could be something else.
Hope I could help.
Posted on Feb 03, 2010
  • Steven Monser Feb 08, 2010
    Guess it didn't help.
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
Philips 47PFL5603D LCD TV ,will not turn on,it did have flashing red lite,insted of green,then it got a clear flashing lite,now there isn't any lite on,I have unpluged it,when you plug it back in,you...
The power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
May 13, 2011 | Philips 47PFL5603D 47 in. LCD HDTV
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
My Acer ASpire M1641 desktop isn't booting, not even to the BIOS screen. It was running & I was on the internet when it flashed a blue screen too fast to read, then stopped dead. I get no display on...
Even though the fan on the graphics card spins, it may still be the power supply. Try another power supply before anything else, its your cheapest option as well as a new motherboard will cost more
if this helped you please vote
Feb 25, 2011 | Acer Computers & Internet
Have a dell gx280, shut it down last night and this morning the normally green start up lite was flashing amber. after looking at some forum most replied with either replacing the mb or power supply which...
It's a pretty common issue with the 270 & 280. More times than not it is blown capacitors at the root of the problem. Replacing the caps is simple if you know how to solder very well & makes for an easy fix. Also, make sure you're pushing enough power through your supply.
Sep 18, 2017 | Dell OptiPlex GX280 PC Desktop
Computer will not turn on ,I tried removing plug in back of computer and plugging in again. The green lite tries to come on and then goes out. The computer has been turned off for several month's. There...
mcdevito75 here, Sounds like the upper fan operateing is also needed to cmplete circut for the computer to come on. Check with Staples, Best Buy to see if that"s true if so, change the fan motor.
Jun 26, 2010 | Computers & Internet
Dell 8200 green power lite comes on green hard drive lite off
Check your fans o see if they are running and if the PC isn't getting too hot because that will cause it to stop and not boot up.
Dec 29, 2009 | Dell Dimension 8200 PC Desktop
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
HP Pavilion m7480n (882780389410) PC Desktop Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
