Question about Zanussi ZWF12070 Front Load Washer
Can not fix the rubber seal back around the drum with the spring it keeps comming off any tips
How to put the rubber back on the drum
Posted on Mar 09, 2011
  • Zanussi Master
  • 3,463 Answers
I would think that you are not getting the spring proerly located in the recess of the door seal, I have found it helps if you stretch the spring a little, this makes it easier to get back on.
Hope this helps.
Posted on Feb 03, 2010
How to change door seal on Zanussi ZJ1218 washing machine
I hope you have small hands,and you are pretty handy with them cos these seals are tricky if its your first.
First remove the nylon clip around the front of seal it will pull off from bottom.then release outer rubber,then you have to just get your hand or fingers to pull at inner rubber,there is a spring around inner rubber lip but to make things awkward there is also a concrete counterweight around this.Once you have old seal out get new one and wipe some fairy liquid around inner lip to refit make sure pointy arrow is at the top.This is the tricky bit and hard to explain but you can only do it by feel and keep trying to get a part of inner lip over casing lip once it starts it can go easy or hard you may have to try a couple of times until you can feel it is on all the way round.Once on the spring has to be fitted its also tricky,start by door switch and put a long screwdriver thru. hole for door catch try to hold with knee or get help.Work it around keep screwdriver in until spring is nearly on keep hand on spring then gently try to remove screwdriver make sure spring on fully,now fit outer seal lip and fit nylon clamp.You may find it easier to tilt machine back slighty.I do this for a living and it can go easy or hard.Best of luck.
May 04, 2010 | Zanussi ZJ1217 Front Load Washer
Washer leaks during spin cycle. my daughter pulled the drum out of alignment temporarily while pulling a comforter out of the washer. the door seal is intact although there is a wire ring that came out...
The spring goes around the door seal it needs to be stretched around the small lip that holds the seal in place. The spring is where you grab it with needle nose pliers. the spring goes on the bottom. You will see where the rubber seal has a wider spot this is where the spring should be right at the 6 o'clock position. This is a little tricky to do the first time trying but keep at it you will get it.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
How to replace seal between door and drum
1. Unplug from mains electricity.
2. Pull machine out from wall carefully.
3. Remove screws in top corners (that are holding down the top panel of the machine) at the back of machine.
4. Remove top panel of machine (slide it slightly in the direction of the back of the machine, it just lifts off).
5. Remove the detergent drawer (pull it right out and put it to the side)
6. Remove the two screws at the top of the gap where the detergent drawer goes in
7. Remove the two screws at the top, front of the machine
8. Now lift out the panel with the control dials on it (etc.). Careful here, you don’t have to disconnect all of them, you should just be able to put this to the side with all the wires still connected.
9. If the old door seal is still on (if not go to 10):
a. Look carefully at the arrangement of the rubber at the lip of the drum and the door rim (you’ll need to know so you can put the new one on)
b. The outer rim is sealed in by a circular wire linked by a small spring. It’s a bit tricky but you can unhook the spring from the wire (using a blunt knife to lever it out – careful not to damage the rubber) to remove it.
c. The inner rim is sealed with a larger circular spring. You can either lever this out with the same blunt knife, or just pull hard on the rubber to get it out, and the rubber off.
10. Now position the new rubber door seal between the drum and the door
11. Grip tight around the outside and inside of the rubber door seal and attach it to the lip of the drum. This is the trickiest bit, and seems impossible but it is doable. The key here is that once you have a bit of it on, the rest will slip on as you work around it the circle. Even at the bottom and sides where your hands can’t reach it should slip on nicely. It ain’t easy, give it time.
12. Now get the spring on the inner rim to seal it (again, not easy, give it time and muscle – you need 3 hands for this!)
13. Then attach the outer rim to the lip of the door rim, and hook the metal wire back in place with the little spring.
14. Put the panels and screws back in in the reverse order to how they came off/out. Make sure there’s no parts left over, ey!
15. There you go – plug it back in and run a test wash. Check for leaks
Oct 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leaks from a hole in the bottom of the drum. The hole looks as if it should be there
15. There you go – plug it back in and run a test wash. Check for leaks.
Oct 21, 2009 | Indesit WA 125 Front Load Washer
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Door seal fitting
Bosch Classixx WFC 2465 Front Load Washer Door
seal fitting.
This video will show you how to change a door seal on this Bosch front loader washing machine and how to get the spring
fixing ring back on.
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 12, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Zanussi ZWF12070 Front Load Washer Logo
137 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
