Question about Microsoft HP Pavilion DV6276US Notebook PC
Hp entertaiment pc problem: display system have running but nodisplay and anther one vga port display working problem lcd display ?
  • 358 Answers
Even though I suspect that there is a problem with
your system LCD too, but before you conclude, try
this out:
When you power on your system, use the function
key combination to try to activate the LCD screen by
pressing fn+f4 repeatedly, this will activate and
deactivate the LCD screen as you keep pressing it.
If after trying this nothing happens, then I'm afraid you
might need to replace your LCD screen...or just get
a second-hand LCD same screen size from a
Computer store and let an electrician fix it for you.
You should be ready to pay a few dollars though.
Also another option is if your Warranty is still active,
then just get an HP Service Center and drop it with
them and let them fix it for you. But remember that if
you want to use the warranty option, never let any
engineer touch the system, or else your warranty will
become void.
Try this out and let me know how it goes.
Hope this helps you out.
Goodluck and thanks for using Fixya
Posted on Feb 07, 2010
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
Hp entertaiment pc problem display STAYS BLACK BUT ALL LIGHTS COME ON
If the Video Controller fails, the screen will stay black when the rest of the computer runs as it should. To test this, look to the side of the computer and locate the external Monitor attachment. It is a nine pin male outlet. Take a regular computer monitor and attach it to the connection and turn on the computer. If the Monitor acts like your normal LCD screen, then the main LCD screen is bad. If Neither the Monitor or LCD works, then the Video portion of the computer may be defective.
Apr 15, 2014 | HP Pavilion Entertainment tx2500 Tablet...
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Power on but no display
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 15, 2012 | Computers & Internet
I have HP Pro3000MT, and it has vga and dvi port. I want to use dual monitor for this pc. the monitor are HP LCD and it only has vga input. first i use vga port, secondly i use this dvi cable to connect to...
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Apr 01, 2011 | HP SmartBuy Pro 3000 MT Pent Dual Core...
I just lost my video output from my HP m7250n. I tried replacing the graphics card and that did not work. I connected the display with its VGA cord to anther computer and it worked just fine. Any ideas?
This particular model of computer is known to have bad capacitors. If the capacitor that regulates power to the onboard graphic chip is bad, you will not get a video output.
enjoy the power of a PC
Mar 15, 2010 | HP Media Center m7250n (ED842AA) PC...
My monitor keeps going to sleep & can not get computer on. What's wrong & how do I fix it ?
it could be the monitor VGA cord is not properly connected to the PC and the VGA Port on the PC is faulty. Try use the monitor on another working PC and see if the monitor displays, if it displays then your PC VGA cord is bad or the display resolution in the PC is too hight. Or if the monitor does not gives the same problem, replace the VGA cord.
Jan 30, 2010 | HP w1907 LCD Monitor
Vista not detecting monitors connected to the VGA port
Try to do the following:
Connect to the new PC, it lowers the resolution of video and connects to the old PC
Dec 16, 2008 | Pine Technology XFX GeForce 7950GT, (512...
VGA compatible?
HP .COM DOWNLOAD ALL YOUR DRIVERS AGAIN USE ANTHER PC SAVE THEM ALL BURN TO CD THEN BRING IT OVER INSTALL IT if cd ect not working do it on usb hard drive from anther coputer download hp drivers for your model on ther site ok then tranfer ove rto broke labtop and install drivers ok thx nick
Oct 06, 2008 | HP Pavilion dv1000 Notebook
Compaq Presario v2000 notebook screen ghosts out and system running slow
for the display you can check by connecting the laptop to the monitor through the vga port
Oct 03, 2008 | HP Compaq Presario V2000 Notebook
Microsoft HP Pavilion DV6276US Notebook PC Logo
71 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
