Question about Refrigerators
I have about 15 yr. old Sub-zero Refrigerator. Lately there are some frost forming on the wall inside it. Please help!
  • 52 Answers
Try to defrost it by un-plugging it, and letting the frost melt. Also, you could try to up the temp settings inside the fridge or freezer and not have it set at the lowest setting. Try the recommended setting from the manufacturer.
Posted on Feb 04, 2010
Testimonial: "After I sent my problem and waited for your replay, but I could'nt get any answer from you. so I gaveup. your return mail solution was not right. "
  • chatico Feb 06, 2010
    Sorry I missed your e-mail, my co-worker was answering the mail, my apologies if he gave you a incorrect answer.
    Sergeant:
  • 226 Answers
Sub Zero has a timer to defrost the freezer [twice daily] which disengages the compressor and turns on heaters mounted on the coil and fin assembly behind the sheet metal cover at the back of the freezer. It also has a fan to distribute the cooled air in the freezer. If the fan fails, you will get frost buildup on the back wall.
If the timer doesn't work, you won't get the defrost cycle, and if it sticks in the defrost position, your freezer will warm up and thaw your goods. If the freezer does not defrost, you will also get a frost buildup on the back wall.
If you hold the switches at the top of the doorframe closed, the fan will come on for one switch if it is working, and the internal lights will go out for the other switch.
The timer is in a little box above the freezer, behind the removable cover. It is mounted to the right side wall, near the front. It has a little hole where you can use a flat blade screwdriver to turn the timer armature. If you turn it, you will hear it click, and hear the fan and compressor [left side compressor] turn off if it was running.
tom
Posted on Feb 25, 2010
Why would I have frost on the back of the refrigerator?
Ice or Frost on Back Wall of Refrigerator ' FAQ ' Sub-Zero ...
www.subzero-wolf.com/.../ice-or-frost-on-back-wall-of-refrige...
Sub?ZeroWhy is ice forming on the back wall of the refrigerator? ... The settings should be 38 in the refrigerator, 00 in the freezer, or 4-6 if the unit has a dial control.
Jan 01, 2016 | Frigidaire Refrigerators
Sub zero 690 side by side help
I need more information to assist you. Which section are you having issues with? Do you have fault codes (these will flash on screen inside unit)? Have you cleaned the condenser (if not please do so)? Do you have ice forming anywhere on the walls? Please get back to me when you can with answers to these questions. Thanks
Jul 26, 2014 | Sub-Zero 690 Side by Side Refrigerator
Frost on back of refrigerator, left side
Just frost or a puddle? If it's a puddle cause by melting frost with no where to go then you had my problem. A clogged drain. First defrost the drain, a hair dryer works well, blow or snake it out then install the factory drain heater fix. Plugs right in and works like a charm. I've had my sub zero 550 for more years than I can remember. I'd buy another one in a minute. Good luck!
Oct 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
Refrige is 48 and freezer is 0 model 532
Fixing Freon Leak by replacing evaporator coil on Sub Zero refrigerator
May 19, 2009 | Sub-Zero 642
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Frost in rear of sub-zero refrigerator above vegetable bins
This is a very common problem. In most cases, it is due to a faulty refrigerator thermostat. I have seen balls of ice as large as a gallon of water on back walls of sub-z refrigerators due to this.
Oct 17, 2008 | Sub-Zero Refrigerators
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Refrig section frosting up
repairing Sub Zero under warranty Sealed System. Evaporator Change Out HD video
Jul 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550
You probably have a freon leak in the evaporator coil.
Nov 01, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
