Question about Microsoft Windows XP Home Edition
Dell Laptop display Appearance setting help needed !!!
On my Dell computer display, each icon has a blue rectangle around the description of the icon. I've seen many computers that do not have this. Is there a setting to make this rectangle go away or become ''clear''? If so, a quick instructional would be appreciated. Thanks !!
  • 109 Answers
1. Right click on My computer
2. Click properties
3. Go to advanced tab.
4. Under Perfomance click Settings
Under Visual Effect
Use Adjust for Best Appearance and Apply.
IF YOU LIKE WHAT I WROTE PLEASE VOTE FOR ME.
Thanks and Good Luck!
Posted on Feb 03, 2010
Testimonial: "Thank you for the quick help.."
Laptop screen problem
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 08, 2012 | Dell Studio XPS 1645 Laptop
Hi I connected an "S" cable from my laptop to my
Thank You Mr. David,
For choosing my services.
I will try my level best to help you,
First start with very basic Troubleshooting steps
1. Switch off both devices.
2. Make connections S-Videos
3. Now switch on Laptop (As you mentioned its dell)
4. Now switch on TV or monitor.
5. Now hold (fn key) and simultaneously press f8 or f7) f8 for dell. (key which contains display icon on it).
6. Fn and f8 key helps in toggling displays in 3 modes-
7. Laptop display
8. Monitor /TV display
9. Both of displays
If you are Using Windows 7 then follow these settings after above troubleshooting steps
  1. Click "Start," access the "Control Panel" and then select "Appearance and Personalization." Find the option that says "Adjust Screen Resolution" and click once. A small window displays with two monitors labeled "1" and "2."
  2. Click on the "Identify" icon and a large "1" appears on one monitor while a large "2" appears on the other.
  3. Select the drop-down menu next to "Multiple Displays." Select the "Extend these displays" and click apply. The desktop is now extended. Adjust the "Resolution" and "Orientation" to complete the customization.
  4. Control Panel\All Control Panel Items\Display (You can choose magnification of your screen. (Medium-100 % recommended) check and set it to medium.
Now Let Me know the status and Exact problem You are facing right know.
Thank You Regards
Sunil Pratap Singh
Feb 05, 2012 | Dell Computers & Internet
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I have a dell laptop with windows 7. i just purchased monitor samsung b2330 23". everything looked great. now for some reason, everything looks normal on my laptop, yet on the monitor looks like it is...
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. To designate the primary display, on the Monitor tab, click the icon that corresponds to the monitor that you want to designate as the primary display, and then select the This is my main monitor check box.
  3. Select the screen resolution and color quality for each monitor that you're using.
Oct 03, 2010 | Samsung Computers & Internet
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
BIG ICONS
This is for Windows XP
1. Click on Start then Control Panel.
2. If control panel is set at Classic View, then double-click on the Display icon which is shown below:
Then go to Step 3.
Click on Appearance and Themes and then click on Display.
3. A box will pop up. Click on the Settings tab.
4. Click on Advanced.
Change the DPI setting to Normal size (96 DPI). If you have the value set on anything else, text on the HUD-1 will look jumbled on the screen.
Click OK and your computer will ask you to reboot your computer. Click Yes.
Apr 22, 2009 | Acer Aspire 5720 Notebook
Wall paper is displayed however not the PPT or Icons
You need to configure your video card.
I'm assuming this is a laptop you are working with. Go into the video card properties, and make sure the VGA port that drives the projector is not set to extend your Windows desktop.
From your desktop, right-click and choose the "properties" option.
In the Display Properties window that comes up, select the far-right tab "Settings".
See the rectangles labelled 1 & 2? Click on the rectangle with the 2, and then look down near the bottom where you'll see a checkbox with "Extend my Windows desktop to this monitor."
Make sure this box is not checked (it most likely is right now, and that's the source of your problem).
Mar 29, 2009 | Epson Office Equipment & Supplies
Aspect ratio changing on ATI radeon hd2400 pro
My wifes DELL has a F key with a blue icon that does that
take a look at the BLUE symbols and see if there is one showing a rectangle with either blue bars on each side or similar
When she presses it the screen changes to a 4:3 aspect with black bars on each side
Jul 03, 2008 | Computers & Internet
S video not working
This is what you need to do:
Connect the s-video from your computer to your tv input. (think you've already done that)
Go to display properties on your laptop (right-click Desktop and select Properties)
Go to Settings
rightclick the blue rectangle, with a number 2 in it and select attach
If needed you can change the resolution for the TV.
Then click OK
Now your computer is configured correctly.
Make sure you have selected the correct input on your TV.
Please post some feedback,
Thanks for using FixYa
Apr 06, 2008 | Dell Inspiron 8100 16MB Video Card - 6H915...
Microsoft Windows XP Home Edition Logo
173 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
