Question about IBM (02R4087) Motherboard
FRU 49P1605 POWER CONNECTOR DETAILS: I want to know how to connect my motherboard on a power button (reset and system power) there is no description on it, ex : ground-reset/power-ground, hard disk activity led-ground and system power led-ground, or wich colour is generaly ground. Thanks.
    Guru:
  • 239 Answers
Normally in most computers white/black is for ground
On the connector u will c a small triangle for +
Posted on Feb 05, 2010
Ibm rev 1.2 fru pn 49p1605
http://www-304.ibm.com/shop/americas/content/home/store_IBMPublicUSA/en_US/Upgrades.html
Sep 20, 2013 | Intel Motherboard
My motherboard is ibm fru pn 49p1605,why is my drive sound not found
It's because you didn't connect it properly ? Broken ? Or you need a driver, to use it ?
Can't find the driver yet, but you could use a utility.
Like Driver Genius or DriverEasy
May 29, 2011 | IBM (09N5424) Motherboard
Where do you attach the two thin black wires coming from the on-off button on the case?
Without knowing what brand and model motherboard, I can only give a generic answer. There should be a group of pin connectors somewhere on the motherboard (usually near the edge away from the expansion card sockets. This group will have labels printed on the motherboard above them with abbreviated descriptions (i.e., PWR for power, HDD for Hard Disk Drive light, RST for reset, etc.). You'll want to connect those to the two connectors labeled PWR, it does not matter which order you connect them.
Aug 10, 2010 | Computers & Internet
Need the pin out for system panel connector on the Asus M2M68-LA Thanks
you can use this simple steps to know the pin details sir.....
1.short any two pins with tester, of the front panel connector pins of motherboard.continue this process until the system will be ON.when the system will be on then ,you found out the power on button.
2.after find out the power ON button ,then again short any two pins with tester until the system will be restart .if restarted then you are founded the RESET button.
3.now jack the speaker button in any pins, restart the system .until you can hear the beep sound. (restart must every time you connect the speaker pins changed)
4.same as you can found the led pins also.
Note: Dont worry about any problem will be affect the motherboard.Becase this is normal Technic sir... 100% you can follow it.Thank u sir... Have a nice day...
Mar 17, 2010 | Computers & Internet
I need to find out where the 3 little plugs go that are connected to the power button theres a blue/white black/white red/white plugs comming from it going to the motherboard
Sometime these connectors from the desktop case front panel have labels indentifing what each connector/plug is for. From your description they could be a reset switch or LED indicators for hard disk or power light etc.
If the plugs are not labeled then trace the wires back to the front panel to identify what they are attached to.
When you connect the LED indicators to the motherboard and it does not light up when they suppose to, then turn the plug around 180 degrees.
The LED are polarity sensitive ie they only light up if the + and - leads are connected to the motherboard correctly.
Nov 08, 2009 | Computers & Internet
Trying too install 4in1 card reader
If its an internal card reader, you should install it in the PCI slot. If it's an external card reader you should plug the card reader into the USB port. I need to know the brand and model of the reader so that I can give you more precise instructions.
Sai.
Mar 01, 2009 | IBM Computers & Internet
49p1605 manual
Start up your computer, Hit F1 go to Bios and see which is the model number of your IBM motherboard (usually is a number like this: 8313-BU7 (example))
Then go to Lenovo.com >> Support Drivers
Select >> Desktops >> Netvista >> Model Number (put yours) >> OS
And get the drivers and all the info about your machine.
Please dont forget to rate my help! :-) Have a great day!
May 01, 2008 | IBM (49P1605) Motherboard
How to reset my computer
Look in the manual and see which jumper resets the bios. That is all I can figure out from your descriptive and well written question.
Jan 28, 2008 | IBM FRU POWER/RESET CARD 73P6310 Power...
IBM (02R4087) Motherboard Logo
473 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
