Question about Buffalo Technology WHR-G54S Wireless Router (WHR2G54S)
I reset by Buffalo router to factory default settings. I can't connect to the internet at all, how can I fix this?
  • 2,260 Answers
If you reset the router , you will need to reconfigure the router.
you don't need CD for that. you can do it manually.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 03, 2010
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
I cannot connect to the internet using my netgear n150 wireless router. The internet light is orange but the modem is working fine and I can connect to the router itself.
When the router is turned on, the Internet light turns amber for about 20 seconds and then turns green. If the light does not turn green, the router has a problem. If the Internet light is still amber 1 minute after turning on power to the router: a. The Internet is not accessible. Confirm that you have the correct internet setting. b. Clear the router's configuration to factory defaults. This will set the router's IP address to 192.168.1.1. c. Turn the power off and back on to see if the router recovers. If its still not working, reset to factory defaults. You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 4). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Jun 06, 2011 | Computers & Internet
Have forgotten the password to log in on my buffalo WHR-G125 router. How can I find what it is or reset it to default?
Reset to factory settings is usually a small button on the back of the unit. It may be a very small hole which you will have to insert a paper clip into to press.
Mar 15, 2011 | Buffalo Technology AirStation WBR2-G54S...
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
How do I secure my Buffalo WZR-G300N? I have lost the pin code and camnt get back in. I have read on another site that to reset the username is: root and Password is nothing (i.e blank). Once this is done...
Some wireless routers have a pinhole reset button on the back of the router. If so, use a sharp point to press and hold this button until the LED lights flash, then release the reset button. The router should be restored back to the factory defaults.
You can then open IE browser and type in the configuration IP address of the router to configure the wireless settings, you most likely need to connect a LAN cable from the computer to the router, configure the wireless settings (ie SSID, encryption etc) take a note of these settings and configure the wireless card on the computer with these settings. Then the computer can communicate with the router without using a LAN cable.
Nov 10, 2009 | Buffalo Technology AirStation Nfiniti...
Linksys wireless G router wrt54gs no connection
Did you try holding the reset button in for 30 seconds or more?
A couple times a year I have to reset my WRT54G back to the factory defaults. I have PC's and laptops connected via CAT5 and wireless. There are a couple of methods to resetting to factory default.
Reset Button Note:
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
The first method involves simply pressing a button located on the back of the router.
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  2. Open up your Web browser and enter “192.168.1.1′ in the address bar.
  3. For the login, leave a blank ID and enter “admin” as the password.
The router has now been reset. You'll need to go back in and set up any passwords or wireless security you had set up before.
Through the Web Administration Pages The second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is “192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn’t, the default is no ID and “admin” as the password.
  3. At the top of the Web page, click “Administration” and then “Factory Defaults”.
  4. Beside “Restore Factory Defaults”, click “Yes”.
  5. Now click the “Save Settings” button at the bottom of the Web page.
The router should now be reset to the factory defaults. Again, you'll need to go back in and set up any passwords or wireless security you had set up before.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection problem
Reset the router back to factory defaults by using the end of paperclip to push a very small button on the back of it. You will have to reset the security if desired.
May 01, 2009 | Computers & Internet
Buffalo WHR-G54S & Virgin Media
Just to let you know if you havent solved it yet, i had this same problem today and i fixed it by pressing the reset butoon on the modem, this was after hours of trying to reset the router
Mar 20, 2008 | Buffalo Technology WHR-G54S Wireless...
Buffalo Technology WHR-G54S Wireless Router (WHR2G54S) Logo
832 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
