Question about Garmin nuvi 250 GPS Receiver
Have a headset that Iam trying to pair to my garmin. It says on the garmin set pin code to 1234 but there is no where on the device to change the code. On the headset instructions it says pairing code is 0000. Hoe do I change the code in the Garmin??
Gramins will not link to devices requiring 0000 code. To get round this I purchased a sony portable blue tooth transmitter which uses the 0000 code. This plugs into the 3.5mm audio output on the garmin and the transmits to your device. Not the perfect solution as the sony is battery powered (approx 10hrs run time) but it works. All the best Julian
The link is
http://www.amazon.co.uk/gp/product/B000I0X0O0/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=103612307&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B000I0TCFQ&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=1T69YR8F1CXGPMRS9JQS
Posted on Mar 18, 2010
Bluetooth asks for pin
the phone is asking for a bluetooth pairing code. Usually 4 digits. It is printed in the owner manual of the device or headset you are pairing with the phone.
Try 0000 or 1234 or 0123
if none of those work, you must look up the pin code in the owners manual of the headset.
99% of the time 0000 is default pin code.
Good luck,
S
Feb 22, 2011 | Samsung S3500 Cell Phone
Tip
PIN Codes for most Bluetooth Headsets
Most Bluetooth headsets have a factory set PIN (Pairing) code of 0000 (four zeros). Other pin codes to try are 1234, 1111, 9999.
This applies to most mono and stereo headsets and many other Bluetooth devices. Devices that have a changable pin code may differ.
If none of the code work for your device please see the user manual or contact the product manufacturer.
For a manual replacement, refer to:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
on Jun 02, 2010 | Radio Communications
Someone change my passkey of jabra bt2070 how i get it
hello first i would like to know if your phone is paired with ur bt device if it is and it is asking for your pin code again most pin codes for manufactures are as follows 0000,9999,1111,or 1234.hope this is the answer you are looking for..now if your device is not connected you need to reconnect the device to your phone ,follow your cell manufactures procedures for connecting your bt device and make sure u set your bt device to discovery mode,then when it asks for the pin code enter one from above most are 0000 but the odd time one of the other codes is required...hope this helps
Feb 22, 2011 | Jabra Bluetooth Headset - BT2070
0000 does not work as a passcode to pair my H700 to my LG phone. I have also tried 1234 and every other combo. What is wrong
The default code is either 0000 or 00000. That is, four or five zeroes.
You can set a new pairing pass code once you connect it to your phone by changing the pairing code from under the connected devices settings in your bluetooth menu.
Jan 27, 2011 | Motorola Mobility H700 Wireless Headset
I have a nokia 3330 pay and go phone it won't allow me to turn on bluetooth what do i do?
Jul 07, 2010 | Nokia 3300
Bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Nov 25, 2008 | Motorola Mobility HS850 Consumer Headset
Code doesn't work!
space.gif I took this off Motorolas website. question.gif What's the pairing pin code and can I change it?
space.gif space.gif answer.gif The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
Are you holding the button on the bluetooth till it turns purple. If not then it wont sync properly. After the Bluetooth turns purple then go to your phone and have the phone look for devices. Check this wbsite for pairing instructions
http://www.motorola.com/mdirect/demos/how2_h700/main.html
Jul 22, 2008 | Motorola Mobility H700 Wireless Headset
Connection
Try deleting all paired device from the parrot and your phone, remove battery from you phone to reset it. Then follow below instructions from Parrot.
Pairing Devices: ** From your car kit:
** Select SETTINGS / ADVANCED SETTINGS / PAIR WITH PHONE / OTHER PHONES
* From the phone:
* Select MENU / SETTINGS / BLUETOOTH / MY DEVICES / SEARCH NEW DEVICE
* The phone will search for available devices
* Select CK3100 from the list of available devices and enter PIN code \"1234\"
* Phone and CK3100 are now paired. Wait for auto connection
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Garmin nuvi 250 GPS Receiver Logo
117 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
