Question about Jenn-Air 36 in. CCG2523 Gas Cooktop
My Teka gas oven keeps clicking. I tried using a
My Teka gas oven keeps clicking. I tried using a hair dryer in case it was water but it hasnt worked. All 4 rings constatly click and spark until the cooker is turned off at the wall.
5 Suggested Answers
  • 1462 Answers
SOURCE: Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Posted on Apr 04, 2007
  • 33 Answers
SOURCE: clicking noise on gas oven
when you were cleaning the cooktop did you remove the knobs and spray ,did any liquid fall were the knobs was taken out from. if yes you wet the burner switches it should dry in a day or so depending on what you used to clean it with to speed up the process remove the knobs unplug cooktop if possible and wipe the switch area if this doesnt help take a blow dryer and dry them that way or try good old fashion wd40 it repels water ,spray each one till yu find the culprit it will stop right away.
Posted on Jan 04, 2008
  • 24 Answers
SOURCE: Oven Clicking Noise
Sounds like you've got the igniter button stuck IN. If so it will probably carry on clicking until the battery runs down.
The battery might be behind the bottom drawer. If you take the battery out and the clicking stops then the striker button is probably glued up with something. Just clean it.
Posted on Jun 24, 2008
SOURCE: Jen-Air Gas range Igniter keeps clicking but not starting fire
01/26/09 My wife decided to give our Jenn-Air a good cleaning. With lot's of soapy warm water she pulled the knobs off and washed under each of them not realizing excess water was now running down the inside of each control knob shaft. The igniter immediately began clicking away as it was being shorted by the conductance of the water now inside of the switch. I had to remove the cover (2-screws) to access the control switches but that is all I needed to do do in order to have clear access. Using her hair dryer it took about 5 minutes of warm air blowing down each of the shafts until the water evaporated and the clicking stopped. Wahla. The old Jenn-Air is back to working order again.
Posted on Jan 27, 2009
My cooktop igniter keeps on igniting for no reason
This problem is due to a short to wires contact on the igniter sometimes this happens after a cleaning of the cook top with water so in this case you just use hair dryer and dry out the ingniter.
Other possible reasons are over heating of the ingniter contact so you have to remove it and clean wire contacts.
Finally the igniter contacts are melt together or sometimes full of burned oil and they need to be replaced. Inginter is not expensive part.
Oct 02, 2010 | Baumatic 34 in. B17.5 Gas Cooktop
My baumatic hob keeps sparking for no reason! i was cleaning it and now they keep sparking and i dont know what to do! also, is it dangerous, will gas be leaking?
No. You have some moisture around your igniters. They will stop eventually or you can use a hair dryer to help them along.
Jan 31, 2010 | Baumatic 23 in. BT62 Gas Cooktop
Sep 22, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Jul 02, 2008 | GE Profile JGP636 Gas Cooktop
Jennair gas cooktop
Sounds like you got water into the ignitor switches on under the knobs. Sometimes it takes 48 hours for this to dry out. Or you can pull the knobs and use a hair dryer on to dry out the switches. Personally I just advise pulling the plug and wait. This is a common issue with gas cooktops and can also happen with liberal use of cleaning products sprayed in the know area.
Jan 06, 2008 | Cooktops
Clicking noise on gas oven
Jan 03, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Spark continuously on
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
Nov 20, 2007 | GE 30 in. JGP336 Gas Cooktop
Starter keep trying to start when cook top is off.
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
Nov 14, 2007 | GE 30 in. JGP337 Gas Cooktop
Jenn-Air 36 in. CCG2523 Gas Cooktop Logo
328 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
