Question about Lexmark T644 Laser Printer
T644 900.43 service RIP software
  • 1 more comment
  • Anonymous Jun 19, 2008
    have the same problem and it keeps coming back - whilst turning it off and on again helps it doesn't solve it.
  • mauromz Jul 09, 2008
    Problem in the printing of Adobe Reader when the file is a network
    printer using Linux returned the error 900.43 - service rip software.
  • Anonymous Sep 25, 2008
    I have the same problem, but with a Dell printer. Turning it off and back on, while disconnecting the network cable, does not fix it.
    Problem Solver:
  • 13 Answers
This is a problem you will see when you use the Postscricpt driver to print certain Adobe documents. Very common with Acrobat 7.
Go into Printing Preference, into the Other Options tab, then into More Options and then Postscript. Check the box next to "Disable Postscript Passthrough"
Posted on Feb 06, 2009
    Genius:
  • 1,056 Answers
I've got a Dell 5210 that is doing the same thing.
In my case, the problem was being caused by PDF print jobs from one particular station.
We changed the PDF paper settings on that station, and it works like a charm.
But there are some other reasons this could happen.
Here's Lexmarks KB on that error
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:601:0:0&docid=ENUS29754
Posted on Jan 21, 2009
When you print, try using 'print as image' option in Advanced, this is an Adobe only option.
Posted on Jul 15, 2008
Even switch it off then on again will work. Same with Dell as well
Posted on Jun 24, 2008
Disconnect network and power cables for a minute, connect them back, turn the printer back on.
Posted on Feb 20, 2008
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
SOURCE: 910 service engine + 900 service RIP software
931 service
Posted on Jul 09, 2009
  • 4 Answers
SOURCE: 900 Service RIP Software
Are there any memory or Barcode SIMM's in the printer? If so, remove them (power off first!) and turn the printer back on and see if it acts normally. I have had 1 instance where the Barcode SIMM has caused that error. The Barcode SIMM had to be replaced. Most other times the 900 RIP error occured, a simple turn off/on "fixed" it (sometimes only temporarily). If all that doesn't help, flash the engine code with the latest from Lexmark support. If that doesn't do it, then engine and/or controller card need replacing.
Posted on Jul 15, 2009
  • 150 Answers
SOURCE: T644 won't print - message says
It means the RIP board is bad. It's under the left side cover. I think the board is around 100.00 and easy to replace. Steven 805-520-3003
Posted on May 13, 2010
Mrinny
  • 94 Answers
SOURCE: What does 900 Service RIP Software error message
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Posted on Aug 02, 2010
Why is Epson Pro 7880 printing double image while in bidirectional
That sounds like your wiper blade that cleans the drum between prints is showing some wear and not cleaning properly.
Running a cleaning cycle may help, but it is likely that wiper blade needs to be replaced. Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
May 16, 2014 | Epson Stylus Pro 7880 InkJet Printer
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
I have a Xerox Docucolor 12 printer which uses a RIP to process files you send from your computer in order to print them in the Docucolor. The RIP model is Splash G640 in an Apple G5 power pc. I have...
get the cables checked and replaced if still the same problem.the software which you are loading from internet are missing some files
the orignal software from xerox is required.
Jul 19, 2009 | Computers & Internet
Lockups and 900.00 Service RIP software errors on C534N printers.
are these printers hooked to surge protectors? 900 rip error is a software communications error and can be caused by any pcb in the printer. any surge, lightning strike,ect can cause the nvram chips to have problems these errors can be intermitten or continuious depending on the damge to the nvram. have you tried isolating any of these to see if it still has the problem off the network?
Jul 15, 2009 | Lexmark C534N Printer
900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
May 24, 2009 | Lexmark C750n Laser Printer
May 04, 2009 | Dell Office Equipment & Supplies
IBM Laser Printer 4537-N01 900.43 service RIP software
I rebooted with the network cable out.. Once up again I plugged it in and off it went.
May 01, 2008 | Office Equipment & Supplies
Lexmark T644 Laser Printer Logo
1,292 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
