Question about Creda W120VW Front Load Washer
The suspension spring came undone and fell accross the circuit board shorting it out. Now it will not change cycle and does not wash. I don't think it is filling properly and it doesn't seem to drain right,so I suspect it has shorted the circuitry needed to switch on and off and fill and empty.
    Novelist:
  • 128 Answers
That sounds like you have right idea. Call your service provider and give them your model and serial number of your washing machine and they can order you a new board. Unplug your washer and switch the board wire for wire.
Posted on Feb 03, 2010
Where is my suspension spring on my washing machine
The suspension springs on your washing machine are used to either suspend the tub assembly from the cabinet or to stabilize the tub assembly to the washer base. They also absorb the vibration of the wash basket while the machine is in the spin cycle. Occasionally these springs will become damaged, stretched or detached which can cause excessive noise and vibration from your washer during the spin cycle. You will need to remove the top or front panel of the washing machine to gain access to the suspension springs. Inspect for stretching or damage and ensure that they are securely attached at both ends. Use caution when replacing the springs as they are under tension and always wear the proper protective clothing. We recommend that you replace all of the suspension springs if any are determined to be defective.
Jan 13, 2017 | Washing Machines
I have a 2001 town car with a suspension problem. I just replaced the air bags. A month later the pump started to run too much. I tried soapy water but found no leaks.Yesterday the back end droped and the...
Having it hooked up to a factory scan tool would be your best bet . Check for DTC'S diagnostic trouble codes . Without testing ,code scan ,we'd only be guessing .
Very complex , the untrained person hasn't got a pray of fixing this . You have no idea what your dealing with . Vehicle Dynamic Suspension The vehicle dynamic suspension consists of the following components:
  • Rear air suspension control (RAS) module (5A919)
  • Snorkel
  • Drier
  • Air compressor (5319)
  • Air suspension switch (5K761)
  • Solenoid valve (5311)
  • Air spring (5560)
  • Air suspension height sensor (5359)
  • Air line
  • Rear Air Suspension Control Module
    A microprocessor controls the air suspension system. The microprocessor and its supporting hardware are contained in the rear air suspension control module. The rear air suspension control module responds to signals from various sensors in the vehicle to maintain the programmed ride height while the vehicle is either moving or stopped. The rear air suspension control module accomplishes this by opening and closing solenoid valves to control the amount of air in the air spring(s). The rear air suspension control module turns on the compressor by applying voltage through the compressor relay to inflate the air spring(s) and raise the vehicle. The rear air suspension control module opens the vent solenoid to lower the vehicle by releasing air from the air spring(s) in response to signal inputs from the air suspension height sensor(s).
  • Rear Air Suspension Control Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1317 Battery Voltage High Rear Air Suspension Control Module GO to Pinpoint Test C . B1318 Battery Voltage Low Rear Air Suspension Control Module GO to Pinpoint Test C . B1342 ECU Is Defective Rear Air Suspension Control Module INSTALL a new rear air suspension control module. REFER to Module-Air Suspension Control . TEST the system for normal operation. C1441 Steering Sensor Channel A Circuit Failure Rear Air Suspension Control Module REFER to Section 211-00 . C1442 Steering Sensor Channel B Circuit Failure Rear Air Suspension Control Module REFER to Section 211-00 . C1722 Air Suspension Height Sensor Power Circuit Short to Power Rear Air Suspension Control Module GO to Pinpoint Test D . C1723 Air Suspension Height Sensor Power Circuit Short to Ground Rear Air Suspension Control Module GO to Pinpoint Test E . C1760 Air Suspension Rear Height Sensor High Signal Circuit Failure Rear Air Suspension Control Module GO to Pinpoint Test F . C1763 Air Suspension Rear Height Sensor High Signal Circuit Short to Ground Rear Air Suspension Control Module GO to Pinpoint Test G . C1765 Air Suspension Rear Height Sensor Low Signal Circuit Failure Rear Air Suspension Control Module GO to Pinpoint Test F . C1768 Air Suspension Rear Height Sensor Low Signal Circuit Short to Ground Rear Air Suspension Control Module GO to Pinpoint Test H . C1770 Air Suspension Vent Solenoid Output Circuit Failure Rear Air Suspension Control Module GO to Pinpoint Test I . C1773 Air Suspension Vent Solenoid Output Circuit Short to Ground Rear Air Suspension Control Module GO to Pinpoint Test J . C1790 Air Suspension LR Air Spring Solenoid Output Circuit Failure Rear Air Suspension Control Module GO to Pinpoint Test K . C1793 Air Suspension LR Air Spring Solenoid Output Circuit Short to Ground Rear Air Suspension Control Module GO to Pinpoint Test L . C1795 Air Suspension RR Air Spring Solenoid Output Circuit Failure Rear Air Suspension Control Module GO to Pinpoint Test M . C1798 Air Suspension RR Air Spring Solenoid Output Circuit Short to Ground Rear Air Suspension Control Module GO to Pinpoint Test N . C1813 Air Suspension Vent Request Exceeded Max Timing Rear Air Suspension Control Module GO to Pinpoint Test O . C1818 Air Suspension Air Compressor Request Exceeded Max Timing Rear Air Suspension Control Module GO to Pinpoint Test P . C1830 Air Compressor Relay Circuit Failure Rear Air Suspension Control Module GO to Pinpoint Test Q . C1832 Air Compressor Relay Circuit Short to Power Rear Air Suspension Control Module GO to Pinpoint Test R . C1840 Air Suspension Switch Circuit Failure Rear Air Suspension Control Module GO to Pinpoint Test S . C1842 Air Suspension Switch Circuit Short to Power Rear Air Suspension Control Module GO to Pinpoint Test D . C1897 Steering VAPS Circuit Loop Failure Rear Air Suspension Control Module REFER to Section 211-00 . U1041 SPC Invalid or Missing Data for Vehicle Speed
Nov 12, 2017 | 2000 Lincoln Town Car
Drum suspension failure
The suspension spring of the drum has come off and this means that the drum is hanging off the center.
The drum is hung with spring and shock absorbers and if one side has come off it will be off balanced. The springs are hung from the corners of the BODY FRAME. Check this out, replace spring if the end had broken or also you can use a good plier to extend the spring head to be clipped.( if broken)
Dec 30, 2012 | Asko WL6532XXL Washer
Machine stops spinning after first few turns.
DOES THIS MACHINE HAVE WEIGHT MESSURING DEVICE OR A BALANCING DEVICE, IF SO IT IS IN THE CIRCUIT BOARD WHERE THE PROBLEM IS ,PULL THE BOARD AN HAVE IT CHECK OR SIMPLE REPLACE IT.
Dec 15, 2012 | Hotpoint WMA64 Front Load Washer
I have a LG WM0642HW washing machine. During the wash and rinse cycles the machine runs really rough and will not turn the drum over. Sometimes the machine will stop and go into the LE error. I have...
Your problem requires very skilled LG technician to check the wiring circuit from the control board to the motor and hall sensor. Very possible that the control board is bad but highly unlikely. Suspect the wiring harness with high resistance to the motor.
Good luck
Jun 16, 2011 | Washing Machines
My washer shakes real bad when spinning and makes a rumbling noise
You washer drum is running eccentric and so there is violent action while it is spinning in the cycles of wash and spin.
The fault gets unbalanced when the spinning cycle is ON as the clothes loose the weight of water and needs a stabilizing with a damper/suspension system.
Hence a fault in the suspension of the drum can be the element of fault. You will need to check if there is friction in drive system, check for free movement of the shaft.
Make sure the dampers are not faulty if so replace.
Finally check if the spring suspensions have gone out of the frame , changed or shifted.If so realign the springs to have the drum in the center.
Nov 17, 2010 | Washing Machines
Changing the battery on My Casio Watch module 1848. Two tiny coil springs fell out. Where do they go? I reassembled the watch where i think they belong, and face is blank.
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Sep 16, 2009 | Watches
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
The detergent door doesn't pop open.
If you push the door closed not far enough to latch and let go of it does it spring back open if not the spring on the dispencer door is broken or has fell off
Mar 31, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
8074 vibrates furiously on spin cycle.Has done so since new.
Check suspension shocks and springs. undone back cover, should be 3 shocks attached to tub. remove top cover and check 2 springs attached to tub.
Jan 22, 2009 | LG WM1812C Front Load Washer
Creda W120VW Front Load Washer Logo
181 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
