Question about Rancilio Silvia Espresso Machine
UPDATE on "No steam from my rancilio silvia. unit about 2 yrs old. i have water delivery..." The unit is NOT heating-hence no steam of course. I see have 2 thermostats on top of boiler-no reset buttons that I see. Thx
  • info20749 Feb 03, 2010
    Thank you! Is working now. Found the reset button.
    President:
  • 1,618 Answers
If there is not a red pin on the top of the thermostats, then the easiest way to tell which one is bad is with an ohms meter or just replace both.
Posted on Feb 03, 2010
My silvia is less than 2 years old. Yesterday I let the steam switch on and forgot to turn it off after steaming. It was on for about two hours. Then it won't heat up either. Should I get new part
On the happy side, if you tried to re-heat the boiler and found this problem straight after it failed, the thermostat may still re-set once the unit cooled down. So leave it a day and try again. Alternatively, it could be a burnt out fuse or on the less happy side, a burnt out boiler.
If no lights come on its a failed fuse. But if everything else is normal but it still wont heat, the best option is to take it for a service to a qualified technician as it may be that the boiler was damaged.
Jul 13, 2012 | Rancilio Silvia Espresso Machine
On my rancilio silvia, 3 way valve not whooshing anymore. Water temperature seems low- around 180* at highest.
There are two thermostats, one for water, one for steam. Replace the one for water. You can get the themostat here
Rancilio Silvia Parts
Dec 06, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia not heating
Unplug machine and remove the top panel, check the thermostats on of them tripped reset and you should be back in business.
May 29, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Not heating up the water
Hi
3 things could be wrong. First is easy to check. With machine on, turn on the steam switch and after about a minut open the steam knob and push the middle switch. Check the water coming from the wand and see if its warm? If it is you need a brew thermostat. Unplug the machine. Remove the water tank. Remove the 4 screws that hold the top on and lift top off. The boiler has 2 thermostats on the top front of the boiler, and the one with the red dot is the brew thermostat and need replacing.
If that didn't fix your problem there is a reset thermostat on the front face of the boiler and has black wires going to it. There is a red button in the middle of the thermostat and needs to be pushed.
If that one didn't solve your problem you need a new heating element. You can do a continuity check on the terminals.
Apr 20, 2009 | Rancilio Silvia Espresso Machine
Rancilio miss silvia dispenses cold water
If there is steam in the machine, the only other problem would be if the portafilter was cold and you are brewing into metal or glass demitasse that has not been heated.
Jan 12, 2009 | Rancilio Silvia Espresso Machine
Super hot water out of the group head on my Rancilio Sylvia
My Rancilio Silva is not making the water or steam hot anymore. Is it fairly easy to replace the heating element?
Dec 29, 2008 | Rancilio Silvia Espresso Machine
Water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Dec 07, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
225 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
