Question about PC Chips (M925G) Motherboard
My motherboard is M925 that supports both SDRAM and DDR memory...what kind of DDR memory will i use that is compatible to my motherboard?and can you send me manual of my motherboard M925 (PDF file).
  • 3 Answers
PC2100 or a.k.a. 266
Posted on Feb 03, 2010
What kind of RAM ( ie DDR , DDR1, DDR2 )is supported by d856gsa ;
Intel D865GSA has two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets It Support for DDR-I 400, DDR 333, and DDR 266, Support for up to 2GB of system memory max CreativeTECH
Jan 05, 2011 | Intel D865GSA (BOXD865GSAL) Motherboard
What kind of memfory do I need for a P4M80-M4 Motherboard? I want to install another card.
Here is the specs of the memory that you can use for this motherboard.
2 x 184-pin DDR SDRAM
PC3200 (DDR400) DDR SDRAM
Maximum 2GB
Jan 03, 2011 | Biostar P4M80-M4 Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
I have an extra memory card: DM, 256M, 32x64, DDR266, S. Is it compatible with my E210882 motherboard?
# Four 184-pin DDR SDRAM DIMM sockets
# Support for DDR 400, DDR 333, and DDR 266
# Support for up to 4 GB of system memory
So the ans is yes provided all RAM's have the same FSB, i.e. 266 & satisfies the above .....sodeep
Oct 26, 2009 | Intel Motherboard
Compatible memory for P4M266A-8233
Hi!
No you can not!
This is what memosticks that mobo of yours supports
DDR 200/266
PC100/133 SDRAM
Max. Memory 4.0GB
Good luck
Nic
Mar 09, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
Memory
Yes its backwards compatible because this mother board supports DDR SDRAM type of memory, But put it mind not to mix the memory PC2100 and PC2700.
Hope that helps..........
Jul 21, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Graphics card upgrade
Not compatable at all.
DDR SDRAM memory uses 184 Pin Dimms
Double-Data-Rate Synchronous Dynamic Random Access Memory, better known as DDR SDRAM or DDR RAM for short, is a type of very fast computer memory. DDR RAM is based on the same architecture as SDRAM, but utilizes the clock signal differently to transfer twice the data in the same amount of time.
DDR2 SDRAM uses 240 Pin Dimms.
DDR2 SDRAM improves on DDR SDRAM by using differential signaling and lower voltages to support significant performance advantages over DDR SDRAM.
If your question has to do with buying a video card that is going to use DDR2 ram, that would be a faster graphics card. You can also get video cards with DDR3 ram which again is even faster.
Oddly enough in respect to system memory DDR2 is supposed to be faster than DDR yet the DDR memory cost more than the DDR2. Go figure.
Click the link for video cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
http://www.google.com/search?hl=en&q=XFX+AGP+8x+512MB+DDR2+video+card&btnG=Search
Need help with anything, feel free & ask.
Have a great weekend!
Mike
Mar 21, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
PC Chips (M925G) Motherboard Logo
380 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
