Do you get any beeps? What model is this? IF YOU LIKE WHAT I WROTE PLEASE VOTE FOR ME. Thank You and Good Luck!Do you get any beeps? What model is this? IF YOU LIKE WHAT I WROTE PLEASE VOTE FOR ME. Thank You and Good Luck!
You can't post conmments that contain an email address.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Do you hear the fans running? Do you hear the hard drive spinning? Did anything ever appear on the monitor?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
It's usual that new desktop PC's have fans sounds and keyboard LED's flashing during booting..There's nothing wrong on that, as long as you can get in to your PC OS.
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Fan spinning hard is usually a CPU issue. If you've made any hardware changes to your computer, undo them.
This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
