Question about LG Vu CU920 Cellular Phone
Battery wont hold charge. Do i need a new battery or is something else wrong?
  • 316 Answers
Hello,yes is battery, unfortunately one problem of your mobile is that it doesn't have enough battery and if you using it a lot every night you must charge it.Generally if you have the mobile more that a year you should change your battery
Posted on Feb 03, 2010
Samsung tab 3 10.1 CE0168 Wont charge or come on ?
have you tried a hard reset?, take battery out and disconnect from power supply then hold power button for thirty second then replace battery and try to power up else hold power button and volume down for 30 secs need to keep battery in for this one, if they dont work you need to contact samsung to get it repaired.
Feb 06, 2017 | Samsung Tablets & eReaders
Reversed polarity on jump start. now wont go into gear or hold charge
OLder cars YEs you can jump it without a battery. But in newer cars that use computers and advanced Eltronic ignition/timing/ful injection you have to have power to the cars computer. without a good battery the car will not run.---------------------------------------------------------------------------------
Renault CAN Clip
Feb 01, 2013 | 2001 Kia Rio
Ok i have a Ibm thinkpad and my charger is stuck on green battery but it wont charge at all. It was working earlier but i turned of the computer the wrong way by holding the power button since i was in a...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 18, 2011 | IBM ThinkPad T30 2366 Notebook
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
My phone wont hold a charge
Battery is done. Won't hold charge. Get a new battery at Fry's or elsewhere if your phone isn't ancient and you love it. Try to find a lithium-ion. I used to buy replacement batteries from Belkin on my older phones and they were quite good. If your phone is ancient, can't find battery or phone is just outdated get a new phone from your carrier. From free with new contract all the way to a few-hundred dollars for a smart phone. You may even have an upgrade discount waiting with your carrier. You'll find something in between that suits you.
Jan 30, 2010 | Motorola Mobility i730 Cellular Phone
Won't charge
if the charger is good, then there is something wrong with the charging port or the battery.
If the battery is very flat before you charge, the charger would not be unable to wake the battery because the battery cell is weak. Its only a desktop charger that can wake the battery cell.
So, test your phone with another good battery, and if it still does not charge, then the charging port is bad as I said earlier.
Best wishes.
Jan 12, 2010 | Samsung M220 Cell Phone
Yzf 600r Wont hold a charge? does it have something to do with the magneto or generator?I bought the bike back from a friend and he wrecked it and put a new generator cover on so he changed everything over...
It's not charging, or the battery won't hold a charge? Get a multimeter and test the generator with the bike running, should be 13.5-14.5 volts. If you get this, you need a battery, if not need to find the bad component in the charging system.
Mar 08, 2009 | 2001 Yamaha YZF 600 R thunder cat
1997 zx9 wont turn over battery dead
YOU NEED TO TRICKLE CHARGE THAT BATTERY TILL FULLY CHARGED AT A RATE OF 1 TO 2 AMPERS IF THE BATTERY WONT HOLD THE CHARGE YOU WILL NEED A NEW BATTERY THE NEW BATTERY WILL NEED TRICKLE CHARGING AT THE SAME AMPER RATING FOR AT LEAST 16 HOURS THE REASON WHY YOUR LIGHT WHENT OUT IS NOT ENOUGH POWER TO SUPPORT EVERY THING FROM THE BATTERY
Feb 02, 2009 | 2001 kawasaki ZX-9 R Ninja
Something keeps draining the battery i have had the started battery and altanator replaced it still dose the same thing????????????
i am haveing the same problem... i have removed all the fusses the car doesnt need to start .. ive put 4 new batteries and an altenator in the car.. and it wont hold a charge .. i disconnect the battery at night and thats the only way the battery will hold a charge..
Jun 28, 2008 | 2001 Chevrolet Monte Carlo
My Dell Axim X5 400MHz Pocket PC wont hold the charge
Some people have said that the original ppc2002 ROM has battery draining problems. If this is something new, perhaps it is a bad battery. Ebay for a new one.
If you think it might be a software problem and you have ppc2002-also known as Windows Mobile 2002, upgrade your Axim with the A04 ROM:http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R63937&SystemID=PDA_AXIM_X5&servicetag=&os=PPC&osl=en&deviceid=4434&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=7&fileid=82832
Other Axim stuff here (make sure to choose the correct operating system - ppc 2002 or ppc 2003): http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&SystemID=PDA_AXIM_X5&category=0&os=PPCA&osl=EN
May 05, 2008 | Dell Axim X5 Pocket PC
LG Vu CU920 Cellular Phone Logo
157 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
