Bush A126Q White and the ''end of programme'' light is staying on
Ive just purchased a brand new Bush A126Q White Washing Machine from Argos, it was delivered only yesterday and last night i used it for the first time, great all done, the ''end of programme light'' came on so i opened the door and removed my washing. I did want to put another wash on but the ''end of programme light stayed on'' and has still stayed on ever since, even though i turned off and unplugged the power and then this morning left it turned on in hope that it would reset itself. But it will not let me override this, and so i cannot proceed with another cycle wash. I checked the manual and it did say that if this light does stay on then it may be something to do with the voltage but as the machine worked and washed my clothes and as my household was only rewired within the last 10 years i do not think it is anything to do with this. The only other thing is that in the manual (which i didn't read until afterwards) it does say before opening the door once cylce has finished turn the dial to 0, which i didn't do, but surely this simple thing would not cause so much problem. Ive called the helpline and they are saying as the machine is new they have no manuals to refer to, so an engineer will be sent out to me. I am astonished to think that a simple thing has caused a problem so soon on, especially as it worked perfectly well throughout the wash cycle. Any ideas?
Thanks
Sorry Jo, I think I may have mis-understood your explanation - is there actually a problem with the machine functioning properly or is it simply that the end of cycle light will not turn off?
If it is the latter then simply turn the dial back to 0 before opening the door from the previous wash, this action tells the washing machine to reset itself as the drum is about to be emptied.
I have the exact machine however as it is graded, it didn't come with any manuals, at the end of the wash I just figured thta this was what I needed to do.
Its almost as if you need to double-declutch the washing machine - return the macine to 0 before selecting another cycle.
Posted on Jul 31, 2010
    Problem Solver:
  • 3 Answers
My bush washing machine model no: a126q will not start
Posted on Sep 15, 2011
How do I remove the front bottom panel of my bush a126q washing machine.
its a click off i would look at the user manual
ive checked and its easy got on google
its a click off afair
all else fails read the manual ....??
i use an eating knifes like taking off a tyre
so as to subdue the strains
jam em in lift it out
too lift out the plastic tongs..
Dec 23, 2014 | Washing Machines
I have a bush A126Q washing machine which I have had one day & the start button has jammed. Does anyone know how to un-jam it or get front panel off? Thanks
If this is a new machine I'd advise you to contact the company-you may viod the warranty by trying to fix it yourself-cheers Denny
Oct 19, 2013 | Washing Machines
Hi, recently bought a bush a126q washing machine, worked perfectly fine after 2 washes. However, firstly the programme starter light doesn't stay on throughout the wash, is this a problem? Then the washing...
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board. It's like rebooting your computer. I did this to mine and it cleared up the problem.
Oct 16, 2013 | Washing Machines
Bush a126q / a146q pause light blinking programme won't start changed fuse Nd cleaned the filter what else could be wrong and what should I do?
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
follow the steps and fix it.
God bless you
Jun 09, 2013 | Washing Machines
Reset switch Bush A146Q
MY ON/PAUSE BUTTON IS BROKEN ON A126Q /A146Q model. i do not want to have to buy a new machine, where can i get this part?
many thanks,
Jul 29, 2012 | Washing Machines
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
Washing Machines Logo
2,045 people viewed this question
Top Washing Machines Experts
