Thank you for the information. I would like to know where i can order a G board model# A1054157A. I looked on the Sony site and they dont have any.Help!
  • marshall Feb 03, 2010
    Thank you! i found it. I cant seem to put it on order . Can you help me
  • 10,594 Answers
A1054157A is available with Replacement Number " 9910999Y1" in Sony Part Store for $65
Click Sony Parts Store for details and online order.
Hope this info will help you.
Thanks.
Posted on Feb 03, 2010
  • Shahid Electronics
    Shahid Electronics Feb 03, 2010
    You need to get register with Sony ServicesPlus (Sony Parts Store) then you can place your order.
    If you click Add Cart link just ahead of part Availability info, that will take you to login page as registered user can order parts online.
    Thanks.
LG 26LH2000 television. Last 2 days when I turned my TV on there was only sound, and black screen.
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 16, 2016 | LG 26LH2000 26 in. HDTV LED TV
Red lite blinks tv will not power up. Sony kdp-51ws655
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero detect circuit failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they repair it and return it). A new board costs about $80 on eBay without having to send them your (core) bad board. Sometimes they are not available and you must send your board in for repair. this is MUCH less expensive than SEARS, which charges several hundred dollars.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D6116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of the "G" board. Unplug the TV set, leave it for 10 hours (to discharge the capacitors). Remove the brown back, carefully unplug the cables, unscrew the two mount screws, and unclip the front retaining tab.
This is the MOST LIKELY failed component, D6301. It is a diode and MUST be unsoldered and replaced. Make sure you know that diodes have a SPECIFIC way they must be installed. Note where the stripe is on the component. You can locate a "good" diode by searching on eBay for "sony a1054157a". You should see a parts kit for about $25, give or take.
One other possible culprit is the D6116 diode. This is a surface mounted component (SMT) and will require a steady hand and a very fine-tipped solder iron. I would replace the D6301 FIRST and re-connect the "G" Board to see if that is the ONLY culprit. If you STILL have the same problem, then replace D6116.
Oct 02, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Sep 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
G-board part number a1054157a
That board is no longer available from Sony. but you can get your G board rebuilt at www.tvrepairworld,com
Jul 19, 2010 | Sony KP-51WS520 51" Rear Projection...
Cant get sound
Name and model of MOBO go to their site and find the driver descriptions for it and download
Jul 27, 2009 | HP Compaq Business Desktop Computer
Sony projection tv picture real bright and not clear
This sounds like your flyback on the D-Board of your tv is going out (The part is around $70.00) and available at www.Sears.com the parts dept have make and model ready ( This is a very common problem with this model of sony tvs) Have a pro do it HIGH VOLTAGE! Please rate in order to keep this site free
Thank you!
Dec 14, 2008 | Sony KP-53HS20 TV
Gow 2
Please go to this Site For Further Information: We are a site designedfor Technical Support, Instructions on Computer and Hardware, and somesoftware issues:
www.gamefaqs.com
Oct 06, 2008 | Sony God of War 2
I have the Sony tv that blinks 9 times
My sony KP-51WS520 blinks 9 time and once in awhile will power on, but lately it does nothing at all. To replace the parts you can try searspartsdirect.com. I tried to replace one part hoping it would fix the problem, but just ordered part A1054157A based on a recommendation of a different comment posted on this web site.
Jul 03, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51Ws520
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Apr 24, 2008 | Sony KP-51WS520 51" Rear Projection...
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Electro Med Services...
