Question about Dishwashers
Kenmore dishwasher M# 665 s#16632000 STOCK# FL4313714 It is leaving about 2in. of water in the bottom once its done with the wash cycle. When I push the drain /cancel button and take drain hose off the sink. It has a small stream but never drains all the water out. Seems to keep the same level. Any Ideas thanks
    Novelist:
  • 128 Answers
I would remove the bottom panel of the dishwasher and remove the drain hose from the pump. On some of the Kenmore Dishwashers you can remove the drain spout where the drain hose attaches to and clean. Sometimes something will catch inside the drain spout.
I hope this helps.
Posted on Feb 03, 2010
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
Jul 26, 2011 | Kenmore Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
No water
Two things to check. First see if anything is holding up the float inside the tub. Located on the bottom right if I remember correctly. I had a fork fall off the rack and do the exact same thing by getting lodged under the float. Second, if there was work done on the plumbing, some debrs may have gotten into the line and clogged things at the inlet valve. You may have water flowing through the inlet line, but maybe clogged at the valve. Need to take that off and check. While you are down there run the dishwasher through a cycle and test voltage at that valve. Also could be the valve or the control board.
Jul 14, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore 655 Ultra Wash- dishes not getting clean and have a residue on them when done washing. Arms appear to swing freely.
Does the dishwasher drain the water properly at the end of the rinse cycle. Meaning, is there any leftover water at the bottom of the dishwasher.
Sep 01, 2009 | Kenmore Dishwashers
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Push start button fills with 2in of water then does nothing
hi there........this fault is usually associated with a faulty flow meter....situated on the lower left hand side of the apliance and is only accessible on removal of the left hand cabinet panel
regards Sir Galahad
Apr 15, 2009 | Beko 24 in. D3421F Free-standing...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Soap is not leaving soap dispenser
sounds like your washing dishes without water. baked on dirt!!!! check under sink make sure water supply is on, next look on bottom of d/w inside tub, theres a mushroom shaped float, grab it and push up and downa few times, if its stuck in up position d/w will be tricked into thinkin its already filled with water
Feb 10, 2008 | Kenmore 15522 Built-in Dishwasher
Dshwasher has water on the bottom after cycle
your drain line is clogged or your pump is bad check both. the drain push a coat hanger down it and see if you can pull anything out.
Dec 08, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
342 people viewed this question
Top Dishwashers Experts
