Question about JVC GY-HD100U High Definition DV Camcorder
Hello Does anyone know about changing the parts on my JVC GYHD 100 U, in order to get back the HDV signal on the firewire? Since I can capture dv signal without any problem, it seems that the HDV circuit on the camera is blown-up... According to a phone conversation with a technicien in Germany who was very good, I think I have to change the following: -1 x processor/ic TSB 41AB2PAP -4 x resistors 798, 799, 800 et 801 NASA6AD-560 Is that right? I need a second opinion... Also I don't know where can I consult the service manual on the web? Thanx in adavance Paul
    Problem Solver:
  • 14 Answers
I have a parts unit 4 sale with complete boards on craigslist the body and vf works but the optic sensor is damaged. I'm based In so cal
Posted on Jul 09, 2010
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
I can't initialize on FCP
If you are capturing HD, go into the menu > IN/OUT REC > i.LINK CONV and set it to off, and A/V->DV OUT to off. Go into FCP and go to the File Menu and select "easy setup". In the easy setup menu set the "Format" to "HDV" and set "Use" to HDV - 1080i60. Click "Setup". Now go to File > Log and Capture (command-8). You're now set to capture. Just queue your tape and hit "Capture Now" or set in and out points and capture "Clip".
If you want to capture SD footage, then on your Sony unit, go to the menu and set the i.LINK CONV to "on". In the easy setup menu you will want to set "Format" to "NTSC" and "Use" to DV-NTSC".
Sep 26, 2008 | Sony GV-HD700 HDV VCR
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
My JVC GY-HD111E isn't located in final cut pro
Are you using HDV, make sure you set the signal to DV on the camera. Does it have a signal out option to switch from video to dv / firewire? Have you checked to see if it is supported? Also just keep trying, turn camera on and off, restart the computer with firewire connected then without. I had this problem with a deck and it randomly started working after my 5th try.
Mar 28, 2009 | JVC GY-HD111E Mini DV Digital Camcorder
My Mac does not recognize my Canon HV 30 DV when i connect the FireWire.
I've been around the block with this for days, including a fresh installation of the software on my MacBook Pro. Sigh.
Here's what seemed to work:
1) Reset Vixia HV30 (tiny reset button behind the battery). Did not change any settings on the camera after that.
2) Installed Canon's software that dropped some canon-related files in Library/Quicktime folder.
3) Opened new iMovie 6.0.3 and Final Cut Express HD 3.5.1 projects (a) FCE (using Easy Setup in FCE) to Apple Intermediate Codec 1080i60 (b) iMovie 'HDV 1080i'.
4) Connected 4-pin --> 6-pin firewire cable out of the camera to a bus-powered external drive and from the drive, firewire 800 --> firewire 800 --> MacBook Pro 10.5.8.
This was a last-ditch, Hail Mary effort. It worked, and the camera showed up in the System Profiler firewire window, too, whereas it had not before all of the above. Still does not show up when hooked directly from the camera to the FW 800 input, but at least I can capture now.
Oct 18, 2008 | Canon VIXIA HV30 DV Camcorder
How to make dvd ,vcd from mini dv without any firewir port
You need and AV capture card to do that if you dont have a firewire port.
Use the supplied AV cable that came with the camcorder, connect the audio (left/white, right/red and yellow/video) to the capture card AV inputs and start capturing. You can make the setting on the capture card, whether it should be captured in DVD or VCD format
Aug 17, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Unable to
HHHhhhmmmm. I'd suggest the DV mode and if you camera has the option to output DV as letter box select this, as it is a faster version to edit with (due to compression of HDV). I don't know the camera but VTR is just the playing mode, so play the file you want while trying to connect. Is the signal coming from tape? If it is catured to the harddrive of the camera you will need to import not capture.
USB does not support video, USB2 maybe.
I
Jan 11, 2008 | JVC Everio GZ-HD7 Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Capturing D-VHS thru firewire (1394)
Here's what you will end up doing. ANALOG CAPTURE. I could help if we knew more about the HOST PC/MACINTOSH machine. It's only my opinion that to get a FIREWIRE ANALOG VIDEO DIGITIZER is not a great idea.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GY-HD100U High Definition DV Camcorder Logo
124 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
