Question about Fellowes Powershred 4800CC Shredder
Our paper shredder won't automatically shut off
Our Staple brand paper shredder does not automatically shut off once the paper is shredded like it used to. The shredder is less than a year old. In order to make the shredder stop, you have to push the power button now.
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
SOURCE: Shredder Problem
Replace the paper sensor switch
Posted on May 28, 2007
  • 18 Answers
SOURCE: My shredder stop shredding. has paper caught in itposted
If your equipment makes abnormal noise when you try to switch on again then gear problem is confirmed else the change over switch should be defective or there may be a open circuit in the change over switch connection I shall advice you to call the service engineer for fixing the problem else take safty pecaution to attempt repairs
Posted on Sep 02, 2007
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
SOURCE: Shredder stops in the middle of shredding and won't shred.
I have the same problem with my shredder. I opened it up and found one of the gearwheels had teeth missing. That is why the partial shredding could not advance further. I was able to remove the part and am now hunting for a replacement.
Posted on Feb 15, 2008
Wont automatically feed paper to shred
there is a small switch or an infra-red sensor that sees the paper. Check it in the slot of the shredder.
Paper Shredder Parts
shredderparts.com/
We sell all sizes of paper shredder gears, switches, blades, etc. to facilitate your repair. We also have shredder replacement parts for crosscut paper shredders, ...
General Shredder Parts - Shredder Repair Services
www.shredderrepair.co.uk/general-shredder-parts-227-c.asp We can supply a wide selection of parts for various makes of shredder some of the ... Paper Shredders ... Please note SRS take no responsibility for loss, damage or personal injury caused by the fitting of spare parts by non SRS personnel.
Paper Shredder Parts ' All brands inc Fellowes & Rexel ยป Document ...
https://www.documentdynamix.com.au/service/paper-shredder-parts/ Document Dynamix Australia has a strong reputation for responsive supply of paper shredder replacement spare parts and support. Whatever brand your paper ...
Jul 17, 2017 | Cars & Trucks
Staple stuck in shredder
First lesson - NEVER put staples through shredder. Have you been able to remove the staple? Switch all power off, and then look at blade section. If still present - remove staple - may need magnet or tweezers. This should fix the problem, but if it doesn't it seems you may have some teeth out of alignment. This will probably require replacing the shredder bar by a technician, or a new unit.
Mar 08, 2014 | Dynex Office Equipment & Supplies
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Ed
Oct 01, 2013 | Office Equipment & Supplies
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Does not stop after shredding
it could be that a paper or a staple is on the sensor and the machine wil not stop until it will be cleaned
its posible that a staple is on the electronic board and short the circuit
Hope it will help
Oct 11, 2010 | Aurora Electronics AS1018CD Shredder
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Motor not shutting off in Fellowes Powerhouse C-14 shredder
this is an issue with your paperfeed sensor. You need to call Fellowes at 1-800-945-4545.
Dec 18, 2007 | Office Equipment & Supplies
Automatic Shredding
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Dec 10, 2007 | Quartet gbc Shredmaster 2240S (Strip-Cut)...
189 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
