Question about Kitchen Appliances - Others
My fryer will not heat up consistently. If i press the reset button, it heats up. But after heating up to a certain temp it shuts down and stops heating. There is power to the unit, it seems like a problem with the themostat.
    Problem Solver:
  • 18 Answers
It probably is a problem with the thermostat. The reset button is probably a high limit. The high limit is a safety device to turn the fryer off if the oil gets too hot. Normally they will "trip" somewhere between 375 - 450 degrees F for commercial fryers. I would suggest placing a temperature probe in the oil and see what the oil temp is when it trips. If it trips at a temp below 375, it is a bad high limit. If the thermostat is set at 350 and the temp goes over 400 then the thermostat is bad.
Posted on Feb 24, 2010
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
I have a Butterball indoor turkey fryer that lost power and the red light went off, is there a reset button on the fryer
There is a thermal cutoff near the heating element just like all appliances that make heat. It's supposed to stop a house fire but makes these appliance companies a lot of money.
Nov 28, 2013 | Masterbuilt Butterball Professional Series...
WHEN FRYER HEATS UP THEN IS LOADED TEMP SEEMS TO FALL AND HAS TO BE RESET
If you manually reset by pressing overtemp thermostat, then check your operating thermostat.. maybe over heating.. if so replace thermostat.. if pilot cuts out completely prematurely without reaching set temp then replace overtemp cut out thermostat as it is faulty.
Cheers
Mar 22, 2012 | Pitco Frialator SG14 Deep Fryer
My keating fryer heats the oil fine to temp set on thermostat but will not re fire when oil temp drops unless I push the high limit button. Don't know if the problem is the themostat or high limit...
Sounds like the thermostat is working because it does heat to the right temperature, right? The high limit switch is to shut it down when it gets too hot, so why that helps the unit relight and heat up is strange? Is this gas or electric? Since hitting the reset or high limit button is what is working, I would start there, and replace that... I don't think either part is super expensive, so replacing both wouldn't be too expensive, especially since you have one of the best fryers ever made... Keating is number one in my book, and I know they are expensive to start with, but these two parts shouldn't be much....however I would start with the high limit switch or reset button... If you need a part, we can get you a price....I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959, or you can ask for Paul too. Thanks, Susan REO
Sep 12, 2011 | Keating Instant Recovery 20AA (NG) Deep...
The item will turn on and begin to heat but it then starts to heat and takes a very long time to get to the temp set. Then once we add the items to fry it stops heating..we cannot tell if it is shutting...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If this is electric then you have a burned out element...
if this is a gas unit,,,
Your problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 09, 2010 | Star 301HLD Deep Fryer
Deep Frier power indicator light is on but will
Most fryers have what is called a hi limit. When the oil temp reaches a certain Max temp this switch opens the circuit and will not allow the unit to heat. On commercial fryers, the hi limit has a really small red plunger button. Push it in to reset.
Mar 28, 2009 | Kitchen Appliances - Others
Pilot goes out when fryer reaches set temp. and shuts-off.
try to change the thermal battery the device that the pilot heats.. other wise there is a screw at the botton of the automatic valve.. try to increase the pilot so it can heat more the thermal battery! u dont have enough voltage to activate the solenoid valve so thats why ur pilot goes off
Mar 09, 2009 | Vulcan GR35 Deep Fryer
Kitchen Appliances - Others Logo
343 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
