Question about RCA F32650 32" TV
You cannot see the full screen on the tv the top and bottom is cut off
My screen picture used to be the full size of the secreen, now there is a border on the top and bottom cutting the picture down like in the movie theatres. How do you get rid of the border and get back...
If you are using cable TV there a button on the remote "*" which zoom in and out. You can also check with your cable company in case you have HD TV and not using a HD box.
Jun 20, 2014 | LG 50" 5700 Series LED HDTV - 50LN5700
Emerson TV cutting off top and bottom of display
Its picture settings should be adjusted. Now it is set to 'wide' format I assumes. If you want to get full screen, the display format should be chaged. Without a remote control, it is not possible.
May 24, 2013 | Televison & Video
The picture is to ig for the screen in any mode - i have it on full and it cuts everything off teh top and bottom sony bravia
try checking the aspect ratio settings on the device feeding the tv if applicable, i.e set top box, DVD player, etc
Ensure the settings match the tv type, e.g, 16:9 for a widescreen tv. 4:3 may cause cropping of the top/ bottom of the picture if this is set
Jul 02, 2010 | Televison & Video
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Jul 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Feb 19, 2009 | LG 42PC3D 42 in. Plasma Television
Screen is cut off top/bottom
I had the same problem on my 47 inch Westinghoust HDTV. It turned out to be a problem related to my satellite tv (Direct TV) remote controller. Someone inadvertently hit the "format" key and jacked it up. I set back to it's original position and get the full screen. Don't know if you have cable or satellite, but this may help someone having this problem,
Nov 16, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
Cutting off the picture
please try once more in the memu on tv
Oct 14, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
RCA F32650 32" TV Logo
69 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
