Question about Dryers
Bendix 74868e or Hover D6040 drum bearing felt
I have to fit one of these the replacement is plain felt on side and a coating of powder on it.
1 Which side is glued to the drum
2 what glue would be the best to use.
Regards
IS
  • Ian S Feb 23, 2008
    Thanks for reply,
    No glue in the pack, but I’ve found a high temp adhesive 135degC and it seems to have worked.
    Ian S
  • 770 Answers
It should have came with a red high heat glue in the pack of the felt if not take it back someone stole it.. then glue the plain felt side down
Posted on Feb 20, 2008
Drum squeels
The drum drive belt2_bing.gif could be slipping especially if it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 08, 2009 | Baby Gear
Squeeking noise when on.
I think the drum drive belt is slipping. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Oct 21, 2009 | Maytag Dryers
Drum is very noisy even when spun by hand
The drum may be off balance because a support wheel or bearing is not operating correctly. A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Oct 16, 2009 | Hotpoint WMA66 Front Load Washer
Clothes dryer has a loud squeak
The drum belt could be slipping. A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 16, 2009 | Dryers
Admiral dryer is rubbing metal to metal very loud noise what could this be
Sep 15, 2009 | Dryers
Admiral dryer started rubbing metal to metal what
Dryer
That is an accurate description
the drum of all dryers is suspended from a combination of
felt pads at the drum ends
nylon glides under the drum
rubber tired thrust rollers.
the rubber tires wear, and the drum shifts, this pinches and wears the felts, then there is enough space to pinch the clothes in the gap
It is a simple enough fix, and well worthwhile, felts glides and rollers are cheap in comparison to new dryers.
Generically all dryers are pretty much the same, so when you go to the parts store, the felts rollers and glides may be labelled whirlpool or kenmore
they will fit exactly, there are very few that fit very many models.
To do the job
  • UNPLUG DRYER
  • If a top mounted lint screen, remove lint screen and 2 screws under lint screen from top of case
  • with a putty knife or other blunt blade release spring clips at front corners of lid, retaining lid to front panel
  • tilt lid up
  • remove 1screw each side 1/3 way down front
  • disconnect door switch wires
  • remove front panel and door
  • pull tensioner to end of its travel against tensioner spring, and unhook belt
    (Note:: position of belt around tensinoer and motor pulleys for reinstall)
  • pull drum out forwards
  • motor, pulleys, support rollers, felts, and glides can now be inspected
good roller
3d57115.jpg bad roller
7133e59.jpg rollers are in pairs, if one is worn replace both
Inspect felts and nylon glides where fitted, any wear - replace
to replace felts
requirements 2 or more pairs locking pliers(visegrips) hitemp silicone adhesive
  • pull old felt off
  • scrape off old adhesive
  • spread gllue on drum edge
  • secure felt on drum with visegrip
  • pull felt into place, clip with visegrip, pull again clip with visegrips, work around until felt is attached to drum and clipped in place
  • allow glue to set
nylon glides, if fitted replace easily, a central screw, or glue
reassemble in reverse order
Oct 09, 2008 | Frigidaire FSE748GF Dryer
I need to replace the dryer belt
The belt on a dryer is inside the body, usually accessed and changed as follows
most base dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • remove screws from bottom bend of front panel
  • lift front panel off
  • remove doo switch cable
  • sent front panel aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
Sep 06, 2008 | Dryers
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
Where is belt on dryer and how to fix drum won't turn
The belt on a roper dryer is inside the body, accessed and changed as follows
  • raise case lid
Notes
May 07, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
