Question about Philips CDR775 2-Disc CD Recorder
Spare parts for Philips CDR775 and Sony MDS-Je440
I need to buy the following items..
1-Power supply module ( 220V ) for the Philips CDR 775-00
1-MD drive for Sony MDS-JE440 Mini Disk Recorder.
1-CD drive for TASCAM CD-A500 Cassete/CD player.
My mail is aguinaldo@bahnhof.st
Thanks
/Aguinaldo
  • 112 Answers
SOURCE: not reading blank cdr audio disks to record onto..
Will it read audio cd's? Sounds like you need a new laser unless you have access to a philips COMPair system to diagnose / realign it.
Posted on Jan 15, 2008
SOURCE: philips cdr 760 cd recorder: OPC FAILED
I have a Phillips 775 CD Recorder, and can only get it to record using Maxell CD-R Music Pro brand blank discs. They usually come in packs of 10 and are in full-size jewel cases. Haven't bought any in awhile and am not sure about availability.Hope this helps.
Posted on Sep 05, 2008
  • 32 Answers
SOURCE: i nead a new manual for a phillips cdr 775 dual recorder
http://www.usersmanualguide.com/philips/home_audio-video__cd_recorders/cdr775_00
Choose your specific model and language. Downloads in pdf format.
Good Luck,
BB
Posted on Jan 06, 2009
SOURCE: Do you do stock spares for the CDR775?
I've some spare parts of CDR 775. Power suply and two drives also. Small bit cables etc.
thanks
Dainius
dainiuspace@gmail.com
Posted on Mar 04, 2009
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
Power
That is not a lot of information to go on, but I suspect there is a problem with the transport or heads which causes it to shut down. I've had similar instances with several of the MD Decks I've had.
On any MD deck if the complex play/recording head which is optical magnetic gets messed up you are probably better off to just buy another unit. The best use for a MD Deck with a bad head is to use it as an analog to digital converter or vice versa; if it has sufficient inputs to do so (the inputs vary with the model).
Sorry I can't be more specific with the limited information you have given. It is probably due to the stress of the head malfunctioning causing the shut down.
Jun 08, 2013 | Sony MDS-JE440 Mini Disc Player
Our mds-je440 is not ejecting the disc, it's not coming up far enough to eject it
Your loader is probably worn out, or you jammed a disc into it. Take off the cover, then take off the loader mechanism internal cover to remove the disc.
I paid $250+ to get a loader rapaired professionally on a JA3ES and the repair did not last, I migrated to units with loader trays like the 20ES and the rare 50ES.
Probably the best thing to do is to get another similar deck since the prices have fallen on most of these units, they are readibly available with anything you could need for minidiscs on ebay. The decks are more popular in Europe and Japan than in the USA.
I recently had to buy a loader belt for a stuck loader tray on my 20ES, it will only work with the right sony band, your unit has no bands, so when the loader is bad you need to replace the entire loader mechanism.
Most MD parts are available on eBay Germany, most sellers routinely ship to the USA.
Aug 11, 2011 | Sony MDS-JE440 Mini Disc Player
The disk will not eject without fiddling it out i:e a scewdriver
Yes, but if you look on eBay, the optical drives are very expensive relative to buying an old machine and using it for parts.
Jun 02, 2010 | Sony MDS-JE440 Mini Disc Player
Sony MDS-JE440 mini disc,single play
If there is a "PROGRAM" button, then you just turn on "program", rotate the knob to what track you want and then hit ENTER. Then when you hit 'play' it will only play back that track. You'll have to repeat this for every track or manually hit the PAUSE button between tracks if you program more than one.
Nov 10, 2009 | Sony MDS-JE440 Mini Disc Player
Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Mar 16, 2009 | Sony MDS-JE440 Mini Disc Player
thanks
Dainius
Oct 27, 2008 | Philips CDR775 2-Disc CD Recorder
Philips CDR775 2-Disc CD Recorder Logo
163 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
