I have an Alienware Aurora desktop that needed a technician to come out and repair. The left side panel was left off after this was done. I have been unable to re-attach the side panel to the case ever since that time. I have tried everything from trying to line it up front to back, bottom to top, sliding it, etc. It always seems to get stuck in the upper left corner where the liquid cooling assembly sticks out a bit, but this should not be interfering with getting the side panel back on. The LED lighting on the left side will not work with the side panel off, because there is a contact board that makes contact with a small plastic piece on the side panel that has metal wires in it. Any advice on how I can get the side panel back on would be much appreciated. Thank you!
  • 835 Answers
I highly recommended calling back Alienware support technicians have them come back and assemble it back together themselves.
You could be having issues reconnecting it do to damage to the case. People make mistakes and him/her not replacing it back like it was could of been more then just forgetting to put it back. Plus, to avoid any cost or damage to your cooling station or your computer. They messed up their responsible, and should fix it free of charge.
Posted on Feb 03, 2010
6 beep codes on my alienware aurrora
I think you need to reset CMOS. in your bios to default values
Mar 07, 2014 | Alienware PC Systems Alienware Aurora High...
My Alienware M9700 starts up but turns off before Windows can start
sounds like a thermal shut down maybe heat sink is full of dust under cpu fan or you need fresh thermal paste on processer
Jan 03, 2014 | Alienware PC Systems Alienware Aurora High...
I have a alienware aurora one of the older models. when i switch it on it comes on fine but then maybe after 10 to 20 mins it switches itself off for no reason. All the fans are working and are dust free...
Could be a number of things but I would lean toward the processor or the power supply. Do you have another power supply laying around you know is good? if so you can switch them out to see if it's the power supply and the same thing would go for the processor. Since you probably don't have either just laying around your best bet would be will be to take it to a repair shop and let them test it for you.
Sep 03, 2012 | Alienware PC Systems Alienware Aurora High...
Hi, Upon boot up I recieve a Thermal Error on my Aurora R3 Alienware. I have BIOS A05. Therefore I cannot access the Alienware Control Centre. Do you know how I could fix this? Many Thanks in...
Download the latest BIOS update from the Dell support website. After downloading the update then install it.
After the update just restart the computer.
Jun 24, 2011 | Dell Alienware Aurora-R3 Gaming Desktop...
So, I just recently purchased the Alienware Aurora computer, and everytime I have turned it on, it says Setup is preparing for first use. I have already updated everything for it. This morning when I...
Sounds like there's some corruption in the windows install. Did you purchase this computer new? if so I would call Dell cause it will surely be a warranty issue. If not you will need a Windows 7 install disc. If you have a disc put it in the disc drive and boot to it and do a repair on windows if this doesn't help you will need to completely reinstall windows 7. Hope this helps
Dec 27, 2010 | Alienware PC Systems Alienware Aurora High...
New alienware aurora pc acting up ever since i got it. Crashes in crossfire during benchmarks or games, first monitor shuts down few seconds after pc follows... Alienware Aurora, i7 730, 6Gig ram, 2*HD5770...
Try going to the alienware website and updating the drivers for all your components, otherwise call dell customer support as they generally provide excellent service.
Jul 03, 2010 | Alienware PC Systems Alienware Aurora High...
Alien Aurora will not come out of sleep mode.
try unpluging it and leave it for a few minutes then plug it back in and try yo boot it up.
Jun 21, 2010 | Alienware PC Systems Alienware Aurora High...
How can I adjust the screen wobble on a alienware aurora m9700 laptop.
Choose Screen ResolutionFor higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpgControl Panel: Display: Settings tab: Screen resolution
May 29, 2010 | Alienware PC Systems Alienware Aurora High...
Mystery blue screen won't let me log on my computer!
IF U CAN GO INTO BIOS GO IN BIOS AND CHANGE FIRST BOOT ORDER TO CD ROM THEN PLACE XP CD IN CD ROM AND RESTART PC. AND REINSTALL WINDOWS..........
Jun 09, 2009 | Alienware PC Systems Alienware Aurora High...
Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
Computers & Internet Logo
David Payne
David Payne
