Question about Fujitsu 24R1 Air Conditioner
24000 btu split ac unit... celiera brand... BIG PROBLEM
I have had this unit for two weeks now. The unit is constantely pumping cold air. Just yesterday the unit starting pumping slower with air filled with humidity and very cloudy. The unit is not pumping as strong and makes some noise and there is constand smokey air coming out. I am very confused and have contacted many and no one has a solution. Is the unit just broke... Is there anything I can do????
  • neel7saiba May 11, 2010
    what is the ambient condition there? is this noise of blower ?
    is the humidity content of air is more?
    i think this smoky air is the problem with weather only. for air pumping please check the motor.
  • 21 Answers
Is this air inside or out that is cold and cloudy?
Posted on Feb 21, 2008
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Outside unit turns on and runs for a long time by itself then shuts off. Does this all day an night long. Notice this after a circuit breaker tripped. Not breaker to unit though. Other parts of house.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other Air Conditioning Repair help. Check us out online.
Jul 25, 2016 | Celiera Celi 24000 BTU Ductless Mini Split...
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
WHERE CAN I GET A PANASONIC REMOTE CONTROL NU,A75C3702 FOR MY AIR CONDITIONER RICK
Send a message to me on Facebook at Connectors Audio and Video Services page. Panasonic is a brand I carry and will do some calling for you. Please include the model number.
Oct 31, 2014 | Panasonic CU4KS24NBU 24,200 BTU...
Room temp 78 degrees with unit setting at 68 degrees. The unit is running (i.e. compressor) but unit not pumping out cold air. To be specific the unit is pushing out cool air just not cold with such a...
Sounds like it could be low on freon I believe these units have about 1.5 pounds of freon in them and are critical in not undercharging or overcharging them if it is a freon 410 ac unit the pressures should be about 135 and both lines cold if is low on freon a service tec will need to be called to try to repair the leak if possiable
Jul 21, 2013 | LG LAN240HSV2-LAU240HSV2 24000 BTU 20 SEER...
Celiera 12000 btu Mini-split ac unit blows cool air but not as cold as in the past. Unit has been installed for 3 years and functioned fine until now. Is it likely that I simply need additional freon?
It's 'possible' but not likely that you need additional freon.
What is more likely is the 'filter' (for inside coil) is dirty and possibly the coil itself - and/or - the outside coil is dirty.
I would check out the filter - if dirty - I would change it and would also inspect the inside coil. If it's also dirty I would clean it the best I could (with a brush of some sort).
I would also check the outside coil and clean it if need be.
Hope this helps.
Jun 09, 2010 | Fujitsu 24R1 Air Conditioner
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
Fujitsu 24R1 Air Conditioner Logo
678 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
