Question about RCA HD52W59 HDTV Projection Television
Part number Hi,I need know the part number for signal board from a hdtv rca model hd52w59 somebody know it? please help me thanks benny leon
  • 1 more comment
  • benny leon
    benny leon Feb 20, 2008
    You rigth willtab! the rigth model number is hd52w59yx39
    appreciate you help...
    Thanks
    Benny leon
  • benny leon
    benny leon Feb 21, 2008
    Thanks Very much Willtab! I Apprecite you help..
    Benny Leon
  • benny leon
    Thanks very much Willtab!! Appreciate you help
    Benny Leon
    Genius:
  • 1,030 Answers
You must have what known as yx extension it will be on the label in small letters hd52w59...yx1 yx39 or something like that
Posted on Feb 19, 2008
  • Willie Howell Feb 21, 2008
    271850 is the rca part number.... for the signal board last check about 167 dollars
Small signal board for RCA HD52W59
Thats caused by the small signal board located on the right side of the set ( Green board with the RCA plug inputs on it. Very common issue with that chassis. The board will have a barcode sticker with an as222 number. You can get replacement boards and any part needed for that model from www.tvrepairworld.com
Jan 28, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have rca hd52w59 that has mind of its own. Turns volume down but not up. Turns TV on but not off. Flashes menu screen on and off. Screen formats changes, etc etc. Is the TV shot or is there a relative easy...
Thats a very common problem with that model which is caused by the small signal board needing replacement. Several version of small signal boards were used in that chassis but the people at www.tvrepairworld.com have replacement signal boards and will help you determine which version you require for your specific version if your not sure.
Jan 04, 2012 | RCA HD52W59 HDTV Projection Television
Should I,change just the resistor that is burned?
Normally if a resistor has burned you will need to locate the cause or a replacement resistor will surely blow instantly in most cases? Is your model the HD52W59 RCA with the ITC222A chassis? If so let me know the resistor board location number such as RP256 etc.
Oct 15, 2011 | RCA HD52W59 HDTV Projection Television
We have RCA Model HD52W59 and the input cable end broke; is that replaceable?
Its possible to resolder the Connector but its a vert precise soldering. Its often easieast to replace the small signal board . You can get small signal boards from www.tvrepairworld.com
Nov 05, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Screen Flickers
This not a DLP set and does not have a bulb that the customer can replace.
It may need a firmware upgrade if avaiable.
Oct 21, 2008 | RCA HD52W59 HDTV Projection Television
Circuit Board
try union electronics. thats where we get most rca parts for my shop.
Oct 11, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59
you can get any board needed at the following link for your model its the ITC222 chassis, they have pictures of the various boards so you can deyermine which board it is that youre needing. Heres the link.
http://servicemanuals.vstore.ca/
Aug 24, 2008 | RCA HD52W59 HDTV Projection Television
Picture too dark
Capacitors on the Ysus is bad. Buy a new Ysus board or change the 14 components on it from a repair kit
Feb 27, 2008 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
