Question about Panasonic DMR-E50 DVD Recorder
No read my Panasonic DMR-E50 DVD Recorder does not read my recorded discs any more , it also does not record or erase as it used to, it just goes to recover and switches off.
  • 1 more comment
  • Nathan_D Mar 11, 2008
    ERASE and RECORD fail to function. DVD machine shuts down and will not play, disk can be troublesome to get back!
    Personally I think its the RAM disks as I have a really old DISK that I have never really used much - this disk still works fine. I wonder if the RAM disks have a fairly limited life of record and erase.
    ND
  • jamie75 Sep 09, 2008
    Hi, My Panasonic DMR-E50 DVD Recorder does not read my dvd-r disks any more though it used to, it will still read normal dvd-video disks ok, though occasionally does not read them either. Any ideas?
  • jaysonness Oct 13, 2008
    My panasonic DMR-E50 also does not read discs anymore. It has always been very sensitive but now, my 2 year old daughter touches all of her discs on the read surface which is probably dirtying the lense. I tried a cleaning disc but does not work. Perhaps I will open it up and clean with alcohol as the other poster suggested. I have always had problems with this machine but always got it to work before. Now I have some unfinalized home movies that are gone forever unless I can find a compatible recorder. Does anyone know of a modern recorder that will finalize the unfinished discs?
    Genius:
  • Panasonic Master
  • 1,689 Answers
Most of the time, it is dirt on the lens of the laser. This can be very carefuly cleaned with a little bit of rubbing alcohol on a Q-Tip.
If cleaning the laser lens does not work, then the fault is more complicated. There are many areas of the DVD machine, and including the laser failing, that can cause no reads or writes. Servicing these can be complex and too expensive to be cost effective.
Jerry G.
Posted on Apr 12, 2008
    Problem Solver:
  • 5 Answers
The DVD-RAM Disk had trouble afeter Multiple recordings or any scratches. Buy a new DVD-RAM Disk and Try using that.
My Panasonic DMR-E50 wont read anything ....
hi there,
there could be a few reasons for this, but the most likely is that the laser has gone in it, ie... not reading any discs. it could also just be a loose cable or connector inside the recorder. the only way to know for sure is to open it up and see i'm afraid :( if its the laser, you will have to get it replaced i'm afraid. Hope this helps
Jan 18, 2011 | Panasonic DMR-E50 DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
Bubble console code for panasonic dmr e50 dvd recorder
hi have seen your plight i have a booklet with codes as panasonic codes 2017 1990 1986 1925 1910 1909 1908 1907 1905 1762 1490 1462 1362 1011 1010 0824 0703 0632 0503 0490 good luck
Aug 31, 2008 | Panasonic DMR-E50 DVD Recorder
Panasonic
There is a manual for a E50S and a E50K. Could one of these be yours? One might be close enough to help. Go here
http://www2.panasonic.com/consumer-electronics/support/
Aug 08, 2008 | Panasonic DMR-E50 DVD Recorder
Difficulty recording and playback
you could purchase a lens cleaning disc some are quite good and reasonably cheap but after 5yrs it may need anew deck
May 26, 2008 | Panasonic DMR-E50 DVD Recorder
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
Dec 21, 2017 | Panasonic DMR-E50 DVD Recorder
Blank disks won't record
FIRST HAVE THE LASER LENS CLEANED
THEN USE MEMOREX DVD-R THIS SHOULD SOLVE YOUR PROBLEM
Oct 20, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic DVD problems
sorry to say but both of these sound like loader problems.ie the optics are faulty,you have to replace the full assy called a loader assy when this happens.Panasonic are the only company who offer part exchange tru authorised dealers.ie send back the faulty one and they will give reduced price on new one,.As to other makes see a lot of sonys with optic problems as well so isint just a panasonic problem.You could also try using ordinary dvdrs instead of ram discs as the optic has to work harder when recording and playing ram disc due to information contained.Hope I helped!
May 15, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
270 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
