Question about Videoseven V7 L19PS 19" LCD Monitor
When switching on the monitor v7 it makes a eletrical arcing noise bottom right corner. has to be switch on/off around 12 times for the screen to light up regards Tony
  • 732 Answers
Sales669, You or a qualified electronics technician will need to open unit for inspection and repair. Do not use unit if you smell ozone and continue to hear noise!!!! Any one or a combination of things can be causing your symptom. Do you have any possibility of doing warranty service, or is unit to old? In fact if it were me, I would disconnect it and use a spare unit until v7 lcd is repaired. Read more of my fixya profile to see if something fits your BLACK SCREEN problem. I would guess that your power supply inside of monitor needs some work done! 12fixlouie
Posted on Feb 03, 2010
Laptop LCD monitor (needs advance help) I have a Dell m5010 laptop that started to display small vertical lines from that bottom left corner going up to the top right corner. I plugged the laptop up to...
Try a different resolution in the monitor to see if that helps. You can do this by right clicking on the desktop and changing the resolution within the screen properties. If that does not make a difference, try searching for updated display drivers either through the laptop manufacturers website or its possible you have a bad controller board for the LCD screen.
Nov 25, 2014 | Computers & Internet
My peugot 207 2010 eletric roof won't work
check fuses.
check 12vd to motor,
no 12, work back to switch
yes, 12, motor make noise
no, motor dead.
motor make noise yes, the roof guides are jammed.
or motor is weak. remove motor and move roof by hand.
is it jammed?
Jul 12, 2014 | Cars & Trucks
I have a Asus lcd vw 202/222 monitor and the buttons on the bottom right corner stop working. Is there and suggestions how to get around this problem or to fix it. Thanks
p { margin-bottom: 0.21cm; }
Sounds like faulty switches, easily fixed. You have 2-3 options.
1. If it's under warranty then send it back to be fixed, although you'll probably have to pay for it to be sent back etc. But anything else will void the warranty.
2. Pay a tv repairman or similar to fix it for you.
3. You could remove/replace it yourself if you're handy with electronics, or know someone who is. The part itself is called a tactile switch and should cost around £1 if you live in the UK. Make sure you get the correct one as they come in different heights and orientations.
Should look something like this:
Tools
1. Soldering iron - 40w+
2. Solder - not acid core
3. Phillips and flathead screwdrivers
Instructions
1. Unplug monitor and open case, you may need to carefully lever the case off with the flathead screwdriver.
2. Find the little board with the buttons on, and identify the menu button.
3. Very carefully heat up the contacts on one side with the soldering iron, you'll probably have to do the two contacts at the same time, and rock the switch the other way, then do the other side, keep doing this until the switch comes out.
4. Either test without switch first or just replace with new switch. Make sure it's securely seated, correctly, and soldered in. Make sure the solder is neat, tidy and doesn't contact anything else.
5. Replace casing and test. If it doesn't work then you'll have been a bit messy with the solder, tidy it up and try it again.
Jan 22, 2011 | ASUS LCD Monitor
Screen is blak, has power
That either means it is not getting the signal from the PC or there is a problem in the monitor. You should try this monitor on another PC first, also check or try another VGA cable. Just need to narrow down the problem to either PC or the Monitor.
Apr 01, 2010 | Videoseven V7 R19WPS 19" LCD Monitor
My screen develops some ghost images after powered up for a few hours. I can actually see some words that appear almost burnt into a screen. Similar to a monitor that has been left on too long if someone...
well you are correct and when it come's with the lcd monitors it is known that when a pixel is subjected to same amount of charge for a long time it might retain the residue of charge even after the amount is changed so this reason why you get this problem and in order tackle this just try to use some changing screen savers or just turn the monitor switch off while you are not around it.
good luck.
Jan 06, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Orientating my Screen after I switch into tablet mode.
You can press the Orientation Button located in the right bottom corner of screen. It is marked with two arrows following each other in a circle.
Moreover, you can set as default the screen orientation you desire in Tablet Properties.
Also, remove the battery for 10 seconds and reinsert. This will enable auto orienting of screen.
Jan 13, 2009 | HP Pavilion tx2500z Notebook
My Dell monitor gives sharp noise when started without connecting to the CPU.When system has started it works fine.Can I know how to solve it please ?
Hi!
I used to have a monitor similar to yours, from the noise you are describing is it like a crack? or an high voltage electrical spark/arc? (Mini lightening flash sound).
The Monitor I had De-gaussed each time it was switched on this is a weird thing that lines up the colour guns. If done whilst in use it gives the brief appearance of a shimmy/shake to the screen.
Have you a menu bar on or near the power on/ off switch? if you do try looking for De-gausse it may inadvertently become switched on to auto. You can De-gausse manually.
I do hope this helps.
Paul 'W'
Onyer~EDson(:0)~[><U.K.
Jan 12, 2009 | Dell E771MM 17" CRT Monitor
Emachine E19T5W Monitor
I have more or less the same problem. Mine only stays on for a second though, but it started out like yours. I took it apart and found that the CCFL bulbs at the top of the screen were so poorly put together that they arced out and in the end melted the end of the back panel bulbs off. The monitor only lasted a year and a half and now it's toast unless I can find new back panal bulbs.
If the screen feels excessivly hot around the corners or if you here a snapping noises (arcing) yours is going the same route as mine. If you want to get rid of yours I'll take it.
Oct 29, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Monitor
Monitor sizes are measured on the diagonal from corner to corner.
A 17" LCD may have a screen width of 12 inches measured from side to side.
If you are measuring a old style CRT monitor (Cathode Ray tube) the visible screen area will be about an inch less as there is about 1/2 inch of plastic frame holding the CRT in the chassis. The manufacturer can advertise the actual size of the screen regardless of how much is actually visible to display information.
If you are talking about software not utilizing all the available screen area to display the image, that is an issue with the people writing the software code not keeping up with the changes in hardware.
In the past year or two, most displays have switched to the 16:9 and 16:10 wide aspect ratios while most web content is still written for the 4:3 old style aspect ratio. Eventually, software developers will catch up with cusrrent hardware.
Jul 25, 2008 | Gateway FPD2275W LCD Monitor
Bottom Quarter of Screen Stretched and Distorted
Sounds as though you have a faulty monitor. Give Acer a call and see if they will change it. They usually offer a 3 year warranty with their screens.
Apr 05, 2007 | Acer AL1912B 19" LCD Monitor
Open Questions:
Videoseven V7 L19PS 19" LCD Monitor Logo
218 people viewed this question
Top Videoseven Computers & Internet Experts
David Payne
David Payne
Are you a Videoseven Computer and Internet Expert? Answer questions, earn points and help others
