Question about Nokia 3230 Cellular Phone
Why my nokia3230 is refusing to accept usb cable:it displays installation error
  • ladipo sarumi
    ladipo sarumi May 11, 2010
    do you have the installation cd?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 16 Answers
Did you check the pc suite software. if possible reinstall it. then if still problem persists you need to format the phone type *#7370# for formatting.make sure you back up all phone numbers and other important stuff in your mobile
Posted on Feb 13, 2010
F380 All-In-One won't print
first of all you need to install the software..these are the steps to install the software please follow the steps below
Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
  9. once the software installation is complete try to print that should work
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
Snoy NW-E105
I had the same problem and struggled with it for some time. I forgot the format feature on the device itself and kept formatting from my pc. This won't work.
The solution:
1. Unhook your device from the pc by pulling out the USB cable.
2. Click the "Menu" button 1 time (found on the back of your NW-E105 player).
- This will show "Display"
3. Click the " |<< " button 3 times (the button to rewind track).
- This will show "Format"
4. Click the Play/Stop button 1 time.
- This will show "Format: N"
5. Click the " |<< " button again 1 time.
- This will show "Format: Y>
6. Click the Play/Stop button 1 time (wait for "really?" prompt), click it again.
Now your device is formatted and will play the files you add to it.
Oct 07, 2008 | Sony Network Walkman NW-E105
I have a new HP All-in-one Inkjet printer which refuses to accept mating with the provided HP 4200 software. I contributed to this by hooking up the USB cable to the printer before installing the CD...
Turn off computer, hook up your printer as instructed, turn on computer and it will reconize the new printer. It will ask you if you have the cd for the printer. say yes, insert cd and follow instructions. make sure you make it your default printer.
Sep 23, 2008 | HP Office Equipment & Supplies
Cartridge
whats your printer model?clean the catridge contacts and the print head insert it again properly then switch off and on,do a hard reset from the menu button ,and make sure your using a genuine catridge most especially if your printer is hp product.that should work
Aug 23, 2008 | HP OfficeJet 6310 All-in-One Printer...
I Have a Hp Deskjet F380 ALL-In-ONE Printer-Scanner-Copier,I Need Know How to install a print driver for my Hp Deskjet F380 Printer.Thank You, I Need Help????
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
Aug 19, 2008 | HP Office Equipment & Supplies
Nokia 3230 download problem
Try to make a new profile or activate you wap settings again
Jun 13, 2008 | Nokia 3230
Nokia3230 USB modem connection to pc for use airtel live
For using Nokia 3230 as USB modem you need Nokia PC Suite and DKU-2 cable.
Download Nokia PC Suite from here:
http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml
1. Install Nokia PC Suite
2. Run PC Suite
3. Connect the phone to PC with DKU-2 cable
4. Wait for a while, you will see drivers are installing.
5. After driver installation your phone is connected to PC Suite.
6. Now click "connect to the internet button", a new window will open
7. Go to settings, next and go to "select your network operator from the list" and select your exact operator there
8. And click finish
Now your is connected to internet.
If you don't have the cable you can also connect the phone to PC via IrDa or Bluetooth if your phone has those connecting devices.
May 20, 2008 | Nokia 3230 Cellular Phone
Mobile problem
You have to have nokia PC suite installed on your pc, and sync via the usb cable or bluetooth. Pc suite works well with vista and xp and is seamless with bluetooth if your laptop supports it. What are you running on your laptop? and what are you syncing with? Outlook2003?
Jan 23, 2008 | Nokia 3230 Cellular Phone
Nokia 3230 Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
