Question about DeLonghi DE500 Dehumidifier
DE 500P - Fan will not shut off
My Delonghi DE 500P dehumidifies fine however the fan runs 24x7 and does not shut off unless the unit is completely shut off. This wastes a lot of energy needlessly. The only available sections for fan setting are low/med/hi (no off, or unselected option). Is the circuit board fried etc? Anyone know how to fix or can service in Franklin, MA area?
  • 30 Answers
If you have the fan icon selected, it is supposed to run continuously. If you use the mode button (not the fan button) to change to relative humidity (the water drop icon), the fan should only run with the dehumidifier.
Posted on Aug 30, 2008
Have a dehumidifier, Delonghi DE500P. Unit operates but no water collecting in bucket.Level set to 35%. Can freon be added to recharge?
the short answer is yes , but id caution you on the need too first?
first check the basics:
bucket full lite not on (blinking)
filters clean ?
both fan and compressor inside running (sometimes the fan runs but the compressor does not?) listen carefull for them both?
if your unit needs recharged odds are it's not financial feasible to do so , first you have to fix cause of gas leaking out ? what ever that is ? then you need to add service ports and finally you need a gas charge , this would or could cost hundreds of dollars , a entire new unit is less 200 bucks unless you do all this work your self , but id tend to think if you had all the tools and knowledge to do that youd not of asked here in the first place
Jul 21, 2015 | Dehumidifiers
What diameter tubing is used with the Delonghi DE 500P pump
George, regular garden hose is what is generally used for continual drainage. Just don't exceed the maximum length of hose, that is listed in your Owners Manual.And, despite what they say about being able to pump water up thru abasement window, it really doesn't work that well. Unless the unit is right below the window,
Hope this helps you and thanks for choosing FixYa.
Sep 04, 2011 | DeLonghi DE500P Dehumidifier
Den 500p dehumidifier fan works but compressor does no activate
Phil, it may simply be a case that you have the humidity extraction level set to high. Try lowering it to 32 - 35%. If your unit is not equipped with an LED Screen, set the manual control to Maximum.
Also, remove and check the air intake filter, to see if it needs cleaning. And maintain at least a minimum of 12 - 18" of clear air space around the entire unit, while in operation.
Hope this helped you. Please let me know. Thanks.
Jun 26, 2011 | DeLonghi DE500P Dehumidifier
Delonghi 500p freezes up at bottom left of coil and then does not dehumidify
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
May 29, 2011 | DeLonghi DE500P Dehumidifier
I have a DE 500p it runs but does not collect water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
Jun 24, 2009 | DeLonghi DE500P Dehumidifier Dehumidifier
Error Code E-3
i don't know if this will help i have a delonghi portable ac and the e3 means not enough voltage to run properly. but it was doing the same thing as yours. i plugged it in where i knew there was good enough voltage and it works fine now
May 26, 2009 | DeLonghi DE500 Dehumidifier
I went back and rechecked. If the fan mode is selected, you can only set the fan at one of the three speeds. If you leave it in the fan mode, the dehumidifier will not come on.
Once the fan speed is selected, it will run at that speed in the dehumidifier mode. The fan will keep running, even when the dehumidifier (compressor) shuts down.
The only way to get it to turn off is to use the clock setting, which either selects how long it stands-by before starting , or how long it will run before going back to stand-by. DeLonghi calls it "stand-by," we would call it "off." DeLonghi calls unplugged "off."
I've never turned mine to stand-by, because it will never get my entire house down to 30% humidity (I have it where my air handler returns air to the basement). I live in the greater DC Metro area, where 75% humidity is considered extremely dry.
Apparently the normal mode of operation is fan on unless awaiting a clock start, or encountering a clock shut-down; either condition puts it into the "stand-by" mode.
Sep 02, 2008 | DeLonghi DE500 Dehumidifier
DE 500P
This tube is likely related to the water pump out feature that these have. They have a pinch clamp on connections, perhaps your clamp is loose or misaligned.
Oct 02, 2007 | DeLonghi DE500 Dehumidifier
DeLonghi DE500 Dehumidifier Logo
326 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
