Question about Toshiba e750 Pocket PC
Without having any abuse or accidents the touch screen no longer operates.It occured when I started up the PDA one morning, when it went through its start up and the alignment of the screen, the touch screen would not operate.
  • junkerc Feb 03, 2010
    I HAVE ALREADY SENT A REPLY. THANKS CHARLIE
  • Toshiba Master
  • 6,993 Answers
such happens because its an electronics. One day it might work and the other it might just come up with a fault.
I would advice that you take it to repairer to check the touch screen if it needs to be changed.
Or if you have a screw driver that can open the PDA, you can simply loose it and check the touch screen area for any necessary adjustments or servicing.
Take care.
Posted on Feb 03, 2010
  • 3,230 Answers
Well first of all you can try a reset, just follow the below link to know how to do reset (with images) -
http://www.hardreset.eu/toshiba_e750_hard_reset_soft_reset_en.html
(Just copy and past the above link in your web browser)
Please post comments if further you have the same problem......
Good Luck!!
Thanks
Can you use a pcb 6473 with the Aqualink RS PDA?
if you bought the motherboard with the PDA it is a PDA board no programming from the one touch you need a RS bezel board RS is for the onetouch you can control with the PDA but no programming with the PDA board you should be able to program from the PDA
Aug 07, 2012 | Jandy Pool & Spa
Ineed the users manual for the compaq C120 PDA 2MB MONO P/N: 266500-001
Try HP's or Compaq's website.
Get online and got to www.google.com In the google search box type: "HP Support" or "Compaq Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals throughout the site.
Jun 05, 2012 | Computers & Internet
The touch screen no longer works on my grandsons' 5-month old leapster. Does the warranty cover that?
Likely, yes. call leapfrog, and ask. However, most warranties do not cover abuse or accidents. If your grandson did something or dropped it, the warranty will not cover that.
May 20, 2011 | LeapFrog LeapSter L-Max Console
Touch screen not working I have reset but screen not working
u have to go any repairing shop n show it then they will set its chip which is internaly connected with ur palm
May 10, 2010 | Palm Zire 31 Handheld
Touch screen is misaligned. When you select an item, it chooses the item to the left by 1-2 spaces. There doesn't appear to be an alignment utility like on my PDA, at least I haven't found one. TomTom...
hi,
this is a common problem in PDA's. the mis alignment is because of faulty circuitry or misfitted screen.
this can be rectified easily, there may not be a reset specifically for the screen , but when you flush the software platform or reset it or re-install it, this will be rectified. if the problem is because of any abuse (rough handling, impact, dropped on floor) it is better to change the PDA.
cheers
Jul 22, 2009 | Tomtom ONE GPS Receiver
Touchflo of HTC Touch 3G won't launch
Hi. TouchFlo is the special today plugin for the HTC devices, and as you realized, you can still use all functions of your PDA without. I think there is an error in the installation of TouchFlo (There can be a bunch of reasons, we have to know everything you did with your PDA in order to guess them), but there is a safe solution for that problem, you can backup all your personal data and software to your PC, then you can hard reset your PDA to its factory default settings. That way both your phone and the TouchFlo will work. In order to hard reset your PDA (after the backup of your personal data), you can follow the steps in this link: (http://www.hardreset.eu/htc_touch_diamond_hard_reset_soft_reset_en.html). Hope this helps.
May 27, 2009 | HTC Touch Diamond Smartphone
Sony NV-U53G touch screen works intermittently
chunk it in the trash like all *** products is being sold re manufactured in to the us....
Mar 19, 2009 | Sony NV-U53G GPS Receiver
Cracked touchscreen
There is no need to replace the whloe lcdscreen, you just need to replace the touch screen & panel which is a thin glasstop on the top of the lcdscreen. The whole lcdscreen is expensive, while a touch panel is much cheaper than that. And we could provide all kinds of PDA accessories. Here are some information for you In general, PDA LCD screen comprises the touch screen. LCD screen acts as a display of PDA or SmartPhone, and the likes, which cannot go without LCD screen. Touch screen is short for touch screen digitizer which seizes the upper part of PDA LCD screen. It is pressure-tactile, runs with gentle touch of stylus, finger and other tele-pointing function-possessed device. Different from LCD screen, the touch screen is an optional component for PDA, SmartPhone, and the likes. A PDA can function well even without the assembling of a touch screen for the availability of keyboard.
Sep 09, 2007 | T-Mobile MDA
Toshiba (Audiovox) PDA Genio e550c
Always start with the simplest answer first, so start by removing any memory cards, attached devices and cables and resetting it again. If you still have the same problem check the manual for the Hard Reset procedure, it may seem you've already hard reset it by killing your battery but it's worth a try anyway when your getting this kind of issue.
Aug 11, 2007 | Toshiba Genio e550
Toshiba e750 Pocket PC Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
